injector size help
Old Aug 21, 2009 | 03:43 PM
bresne61's Avatar
bresne61
Navigator
Default injector size help
I'm building a 383 stroker engine with procomp aluminum heads (190cc), hedman shorties, edelbrock IM base and runners, and a cam with 490 degrees of lift...
I bought a set of 36 lb. injectors, and after speaking with the guy from summit, he thought I was crazy (which may be the case ). I have an adjustable fuel pressure regulator, and I'm going to get a chip burned...I was wondering if that would be too much injector, or could it be managed with the afpr.
I know you can tune to a point, but I didn't realize stock was only 22lb, so I bought way too big.
Should I buy another set (if so, what size would you recommend), or can it work with these?
thanks a lot guys
Old Aug 21, 2009 | 03:45 PM
Demonic85's Avatar
Demonic85
Yeah 36 lb injectors are probably a little too big. You'd be better off with something around 24-30. You could keep the injectors and put a bigger cam in
Old Aug 21, 2009 | 04:30 PM
bresne61's Avatar
bresne61
Navigator
yeah, I figured...I just bought a set of 30 pounders
Old Aug 21, 2009 | 04:59 PM
floridamale's Avatar
floridamale
You should of called Jon @ FIC he would of given you the right information
Old Aug 21, 2009 | 05:51 PM
StealthLT4's Avatar
StealthLT4
PM forum member FICINJECTORS, or go to www.fuelinjectorconnection.com and shoot Jon a line. He can tell you exactly what you need.
Old Aug 22, 2009 | 03:22 PM
powerpigz-51's Avatar
powerpigz-51
I am very interested in how this combo will perform. I have yet to hear of anyone putting the Procomp heads on a TPI, and it sounds like you have your cam size about right for this combo. 30 # injectors would be as high as I would go. Please keep us informed when you get it running, sounds like a winner to me.
To injector size help
