Brake Fluid
Old Aug 22, 2009 | 04:33 AM
GS023's Avatar
GS023
Default Brake Fluid
I am working on a GS replica that has C4 suspension and brakes (no ABS). We are having trouble getting a good pedal. Have bled the master cylinder and complete system many times. Car has an electric vac pump for assist. The only thing different is that is has DOT 5 (silocone) fluid in it. Any suggestions?
Old Aug 22, 2009 | 05:43 AM
jan-erik's Avatar
jan-erik
Hi I usethe Castrol SRF. Its the top grade of the Castrol portefolio. It manage extreme heat and is not so picking up humidity as easy as other liquids. I am very satisfied with it.
You appreciate it when using the brakes hard over a period. No spongy pedal
Old Aug 22, 2009 | 07:39 AM
samsonb's Avatar
samsonb
I don't think you are supposed to be using Dot 5. Kinda like dumping tranny fluid in the engine. So, you'd probably wanna flush that out quick many times to make sure all that Dot 5 is out of there. As I believe it eats up stuff.
Old Aug 22, 2009 | 11:36 AM
c4cruiser's Avatar
c4cruiser
Flush that DOT 5 fluid out! Get a couple quarts of a cheap DOT3 fluid to completely flush out all of the silicone fluid. DOT5 is not recommended for ABS systems as the fluid will cause cavitation in the pump and create air pockets. Even without the ABS system in the car, it's not really intended for the later brake systems and the rubber seals.
Did you remove the extra lines going to where the ABS pump was located? Have you tried pressure bleeding the system? Sometimes a simple gravity bleed can pull air pockets out. It's also possible that a hard line may have a slight leak at a junction or a flare at the end of a line is cracked. If you added new hard lines, are they all double flares at the ends? Is it possible that there could be some thread damage at unions?
There are some excellent DOT4 fluids that will work much better. MOTUL 600 and Castrol SRF have some of the highest wet boiling points and they are great for road racing.
Old Aug 23, 2009 | 05:47 AM
GS023's Avatar
GS023
I'm not a fan of the stuff either but the owner must have it.
This is a tube chassis GS replica and all the lines are new using C4 calipers and master cylinder. Front and rear are totaly independant from the master cylinder out.No ABS. I'm will check all the connections.
Old Aug 23, 2009 | 07:19 AM
samsonb's Avatar
samsonb
Originally Posted by GS023
So he knows he is using the wrong brake fluid that will cause damage and has decided to keep using the wrong stuff?
Old Aug 23, 2009 | 10:11 AM
c4cruiser's Avatar
c4cruiser
With no ABS on the car, the silicone fluid won't necessarily "damage" anything. It's just a fluid that I would not use with C4 brake parts. The older C1 to C3 brakes can use a DOT 5 silicone fluid but that may be due to the type of rubber seal in those components.
I assume you have bench bled the master cylinder before installing on the car?? Any air in the MC could be the cause of a soft pedal.
There is a DOT 5.1 fluid that is not silicone based; I wonder if that may be what the owner wants to use??
Old Aug 23, 2009 | 06:52 PM
samsonb's Avatar
samsonb
Oh, I had heard the Dot 5 will cause damage in other places as well as the ABS.
Old Aug 23, 2009 | 06:59 PM
GS023's Avatar
GS023
The main reason the owner likes silicone is that it will not hurt paint. Will 5.1 act like regular fluid in that respect?
To Brake Fluid
