Wheel dilemma
I've been told that the bolt pattern and offset for 88 thru 04 Corvettes are the same, the rims are interchangable as long as it's not a real C5-ZO6.
I want to put 17X9.5's on the front and 18X9.5's on the rear........Here's what I run into.
For a 18X9.5" wheel the bolt pattern is 5x4.75" or 5x120.65mm, offsets are: +56mm with a 6.95" back spacing and a center bore of : 70.7mm
if the rim width is under 10". Same for a 17X9.5" wheel, if the rim width is under 10"
When I go to look at wheels "anywhere" I run into "Oh no, those wont fit, you have to buy the $400 each ones or they wont fit right, you cant use the $200 ones you were looking at........or I need some such of an adapter or some thing else. Zip Corvette has a set I want listed for C5's (17X9.5's and 18X9.5's) fits non ZO6 cars, but not listed for C4's. I call ZIP to ask "will the fit a 96 C4" and I get "I dunno"? Duh ! I'm starting to feel like the Aflac duck here.........any ideas are more than welcome.
A quick question! Why are you so interested in runnning a 17/18 combination both at 9 1/2" width? If you're dead set on the 9 1/2" width I don't understand why you wouldn't want to do a 4 of one or the other!
17x8.5 and 18x9.5 were the standard OEM C5 Corvette wheel sizes which fit perfectly on the 88-96 C4 Vettes. The 56mm offset is the standard OEM C4 Corvette offset for the 9.5" wheel width which came standard front and rear on the 88-92 Vette's.
Order the wheels and you'll be Happy!
17x8.5 and 18x9.5 were the standard OEM C5 Corvette wheel sizes which fit perfectly on the 88-96 C4 Vettes. The 56mm offset is the standard OEM C4 Corvette offset which fit perfect with the 9.5" wheel width which came standard on the 89-91 Vette's.
Thank you
Thank you
That's all I wanted to know
Thank you
17x8.5 and 18x9.5 were the standard OEM C5 Corvette wheel sizes which fit perfectly on the 88-96 C4 Vettes. The 56mm offset is the standard OEM C4 Corvette offset which fit perfect with the 9.5" wheel width which came standard on the 88-92 Vette's.
FIT yes! HAPPY? MAYBE NOT!!
Notice I mentioned wheel/tire "combination" - the FINAL FIT appearannce is the wheel/tire "fitment" in the wheelhouse.
There's considerable thought required to buy for "fitment"!!
My 91 Vette has reproduction 17x9.5 C5 ZO6 wheels with a 54mm offset which fit Perfectly front and rear. I wanted to buy the OEM ZO6 wheels but, the Tire choices and cost for the rear 18x10.5 wheel was Very expensive!
my car is a 96 and has rims off a 98. they are gm wheels. fit fine no issues.
