Opti vacuum hoses
Old Aug 22, 2009 | 09:16 PM
schimek3624's Avatar
schimek3624
Default Opti vacuum hoses
I have a '95 corvette and am putting the water pump back on. How are the vacuum hoses to the opti routed? Do they both go behind the driver side ear of the water pump and thus is sandwiched between the water pump and the engine block? Or is only one behind the ear of the water pump and the other in front of the water pump? Or???
Old Aug 22, 2009 | 10:15 PM
eguyett1985's Avatar
eguyett1985
They tuck in next to the drivers side of the water pump and run up the front bracket. You should have a small spring steel clip attached to that bracket that will hold them in place. I run them on the engine side of the spark plug terminals on the opti cap.
