A few ? on cam and head work..
Old Feb 18, 2002 | 12:27 PM
gears's Avatar
gears
Default A few ? on cam and head work..
Next month Im getting my hot cam kit put in and going to have the heads ported too.Should I replace the timing chain and gears(52,000 miles)?And I also understand I should put a LT4 knock module in too.Now ,is the sensor the same ,or is it different too?
Old Feb 18, 2002 | 12:53 PM
1MoorTym's Avatar
1MoorTym
Default Re: A few ? on cam and head work.. (gears)
I'd do the chain/gears only because you're in there anyway. Its probably ok, but nows a good time to go with a good true roller if there's not one in there already.
I alway talk myself up :D
BBA's Avatar
BBA
Should you replace timing chain/gears...YES
Old Feb 18, 2002 | 01:31 PM
GlockLT4's Avatar
GlockLT4
Default Re: A few ? on cam and head work.. (BBA)
:yesnod: :yesnod: Your car will go 52k more miles without having it break ;)
[Modified by Glock'94, 1:54 PM 2/18/2002]
Old Feb 18, 2002 | 02:35 PM
vettes's Avatar
vettes
Its one of those might as wells,I had a head gasket done and a few other things done at the same time u will save labor charges in the future.
Old Feb 18, 2002 | 02:49 PM
MrJay's Avatar
MrJay
I dont know how much the timeing chaine is going to cost but it will be much less then have somebody do all that work again.
I would do it if it was me.
Jay
Old Feb 18, 2002 | 03:56 PM
GlockLT4's Avatar
GlockLT4
Default Re: A few ? on cam and head work.. (MrJay)
I think the distributor gear is around $25, the waterpump gear is around $15, and the chain is around $20. So I'd say around $60. Definitely worth it to replace it while you're in there.
[Modified by Glock'94, 1:56 PM 2/18/2002]
Old Feb 18, 2002 | 04:05 PM
ASRoff's Avatar
ASRoff
The sensors are the same all you need is the module it is located on the underside of the computer behing the small access pannel thats held on by two screws.
Old Feb 18, 2002 | 05:24 PM
jay17's Avatar
jay17
Are you doing the work your self? When you get it together, be sure and let me know when you're going to the track.
Old Feb 18, 2002 | 05:36 PM
Zix's Avatar
Zix
If you're going to replace the timing chain, you should consider getting a Cloyes HD unit, much better than the stocker. GMPP has an HD unit that is made by Cloyes, I know it fits the LT4 so it should fit the LT1 as well. The GMPP chain is part # 01237-0835, it's not cheap if I remember correctly but when you see the difference you'll be amazed!
Old Feb 18, 2002 | 08:26 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: A few ? on cam and head work.. (Zix)
The right way to go :yesnod: :yesnod:
Old Feb 18, 2002 | 09:26 PM
RichS's Avatar
RichS
Default Re: A few ? on cam and head work.. (mackeyred96)
Put the extreem duty LT4 chain in. It runs about $200 but it well worth it. The chain on my 95 LT1 was pretty sloppy and it only had 30,000 miles on it. My GS chain was sloppy also with the same miles. Replace it while it's apart.
GS #883's Avatar
GS #883
You should definitely install the GM H/D timing set. No doubt about it. Your chain right now is loose. With stiffer valve spring settings, there will be more load on the chain and it will continue to wear MUCH QUICKER, especially with the higher rpm that the motor will turn. If you are going to play, don't short change on the items that will prevent a disaster. Make sure that your push rods, retainers, and locks are up to the new cam. More Performance has some great prices on this stuff.
Old Feb 19, 2002 | 03:24 AM
gears's Avatar
gears
Ok....Im going to go with the HD from GM unless I can get one cheaper somewhere else that is as good.Thanks guys.
Jay17...no,Im not doing the work myself.I wouldnt want to try and port my heads.Im having it done by a guy in Stillwater.He works at Mercury Marine,and does alot of LT5 heads.
[Modified by gears, 1:29 AM 2/19/2002]
Old Feb 19, 2002 | 12:12 PM
jay17's Avatar
jay17
Do you mind telling how much it's costing?
To A few ? on cam and head work..
