Forum's Help
Old Aug 23, 2009 | 05:12 PM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Default Forum's Help
I am not much of a mechanic but my horn did not work. After reading some posts I decided I would take a chance to try and change out the horn, turn signal cam. I did some research here on posts that were done a long time ago until somewhat recent and pulled of the air bag, steering wheel, SIR coil and lock plate as instructed from this forum. I completed the job and the horn is working. Thanks guys!
Old Aug 23, 2009 | 05:20 PM
pianoguy's Avatar
pianoguy
Those who have been kind enough to share their experiences have provided a valuable resource, indeed!
Old Aug 23, 2009 | 06:21 PM
joe3906's Avatar
joe3906
My horn is low sounding, but if it takes the above to change it, I'll live with it.
Nice Job.
Old Aug 23, 2009 | 07:04 PM
george4's Avatar
george4
Nice Job.
If you have a horn that works but is weak like I did on my ’89, try this: Unbolt the horn and spray WD40 liberally into the trumpet. There is a small adjusting screw on the same side of the horn as the plug. Keeping tract of where you start, screw it in and out a turn or two, trying the horn each time. My horns have been working well for several years after I did it.
Old Aug 23, 2009 | 07:10 PM
76yellow's Avatar
76yellow
I did the same as george. Mine had water in it somehow, but the WD did it !
Old Aug 24, 2009 | 01:54 PM
90EXPVette's Avatar
90EXPVette
How long did it take you? I changed the radiator on my 90 last weeked and the horn is next on my project list.
Old Aug 24, 2009 | 05:25 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Glad to hear it
How did you de-arm the airbag?
I need to replace the bushings in my tilt mechanism.
Old Sep 27, 2009 | 08:41 AM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Originally Posted by BrianCunningham
Glad to hear it
I took out the fuse for the air bags, disconnected the battery, and unpluuged the air bag plug near the base of the steering column under the dash. Took the air bag out and unplugged it then removed.
Old Sep 27, 2009 | 10:02 AM
tblt44's Avatar
tblt44
I just put 2 new horns on mine.
Bought 2 horns a high and a low from advanced for 16 bucks each, they were Famm brand and came with there own mounting brackets.
1)Remove the old horns.
2)Drill out the 2 spots there welded on to remove the factory conecctor.(about 1/8 drill I think)
3)Now on the new horn drill a hole same size thru the conection on the hot conection of the horn.(it already hase a small 1/6 hole you just gotta drill a biger one.
4)Deturmine the hot side of the conector and clean it off.
5)Find a small bolt and nut connect the hot side only horn to connector.
6) Ground the other side to the body.
7)Now you can use the factory conector and only spent 32 bucks on 2 horns.
Note I did this a month ago maybe I missed a size or step but I hope you all get the point.I should have took a pic.I will start taking pics of all my stuff I rig up.
Old Sep 27, 2009 | 01:41 PM
pologreen1's Avatar
pologreen1
it is a huge part of what makes this forum.
To Forum's Help
