Gasket sets...
Old Feb 18, 2002 | 02:28 PM
85z51vette's Avatar
85z51vette
Default Gasket sets...
Is there a complete engine gasket set you guys would recommend? I'm putting aluminum heads on my '85 (113s), so would I be ok with a steel head gasket or should I get copper? What about header/manifold gaskets for the D-port heads? TIA...
Old Feb 18, 2002 | 02:47 PM
dtorc4's Avatar
dtorc4
Default Re: Gasket sets... (85z51vette)
Use Fel-Pro # 1003. That is what AFR recommends for their aluminum heads. It is what I am using. They are $27.50 each from scoggin dickey. :cheers:
Old Feb 18, 2002 | 03:00 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
This is a very good question and Im sure the others will chime in with more info.
Theres a specific type of head gasket suggested/required for use with alloy heads and a cast iron block.
I have the fel pros head gaskets for my 86 with alloy heads but have also heard some people say theres a problem with them,but Ive seen no problems yet.I think it was something about the rings coming apart or corrsosion.
Ill let the others chime in for the suggestions.
However, fel pro has a good "Intake and Up"
gasket set that includes everything you need for the intake,runners,plenum,tb,distributor,etc .
Ive used that and its a good kit.
Some people Ive spoke to use the Fel pro intake and up TPI kit while buying a different brand of head gaskets.
Old Feb 18, 2002 | 04:09 PM
GlockLT4's Avatar
GlockLT4
Default Re: Gasket sets... (dtorc4)
Another Vote for Felpro! :yesnod: :yesnod:
Old Feb 18, 2002 | 04:11 PM
dtorc4's Avatar
dtorc4
Default Re: Gasket sets... (Bill's86Coupe)
CHIME :nopity
Yes. According to AFR, they have had problems with the Fel-Pro 1010 gaskets. Apparently, the stainless steel wire in them comes loose sometimes and tends to hang down in the intake chamber, heating up really good and causing predetonation. That's why the changed their recommendation to the 1003. :cheers:
[Modified by dtorc4, 8:12 PM 2/18/2002]
Old Feb 18, 2002 | 04:24 PM
85z51vette's Avatar
85z51vette
Thanks a lot guys. Fel-Pro 1003 it is for the heads. What about the header/manifold gaskets?
edit: I'm gonna make this a dual topic post. :D I'm rebuilding my motor. Do you all think I should have the assembly balanced also?
[Modified by 85z51vette, 2:30 PM 2/18/2002]
Old Feb 18, 2002 | 08:37 PM
MagRed_04's Avatar
MagRed_04
I would reccomend the Fel-Pro gaskets as well!
:cheers:
Old Feb 18, 2002 | 08:47 PM
dtorc4's Avatar
dtorc4
You should since it will be easy enough to have done, but it's not absolutely necessary. :cheers:
To Gasket sets...
