they are the same head but have lt4 springs on them instead of the factory L98 spring. your stock rocker arms are rail style so they would work.. for the money i would buy a better set of heads than those.
i unlike others am not going to sit back and tell you buy brand x head... depends on your budget and what hp goals you are looking to reach which it doesn't really seem like you are cause you are only looking into factory castings.
A set of Patriots would be much less, pick up some power too.
Heck even some Edelbrock performers will improve it for about $1000/pair and are better imo than the GM heads.
a set of patriots would be much less, pick up some power too.
Heck even some edelbrock performers will improve it for about $1000/pair and are better imo than the gm heads.
From: One day you're a Comet...the next day you're dust... Arkansas
My old cyl heads are leaking coolant, and instead of spending money on them i am considering replacing them.
Are the heads cracked or is just the gasket blown? If the heads are good otherwise, and you're not going to go crazy with mods, it's not an expensive fix if you DIY.
Edit
Just called Summit...Edelbrock 60859 are $1309 a pair, wow they have gone up $300/pr since last time I checked.
Maybe shop around and see if there are some for less but Summit is usually the lowest or one of them.
I wouldnt spend that much on them, youre in the $ range of a real nice AFR which is probably overkill for what you have.
See if we can find a link and see what Patriot offers, Trick Flow so far looks like the best for the $ so far.
