Car is running again
Old Aug 26, 2009 | 02:02 AM
Snakecharmer383's Avatar
Snakecharmer383
Default Car is running again
At the risk of bringing back and older thread and being flamed I'll just give the foot notes - The thread "alarm issues" was about how my vette wouldn't start after my dad accidently tried to start the car after triggering the Forced Entry Alarm. The starter would spin but the car would not turn over. Starter was taken off and tested on a the bench where it worked fine. Placed into car and still nothing...Well today the new starter went in and it fired right up. What a sweet Sound to hear!!
So in closing, the starter went bad or trying to start the car with the alarm going off does effect the starter so the car will not start ever again. i.e. effecting the bendix/solenoid??
Either way I lost about 1 month of enjoying my vette but its back!!
Old Aug 26, 2009 | 03:20 AM
pologreen1's Avatar
pologreen1
cool, it would be a shame to have that car sitting.
Old Aug 26, 2009 | 09:17 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
That's a weird one
Glad you got it figured out.
Old Aug 26, 2009 | 09:29 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
That is weird. Nice to know no one will be driving away then if they break into my Vette!
Glad you got it fixed!
Old Aug 26, 2009 | 01:55 PM
383vett's Avatar
383vett
The alarm in no way would affect the starter solenoid. Had to be a bad starter. Glad you're running again.
Old Aug 26, 2009 | 10:21 PM
mtwoolford's Avatar
mtwoolford
the gear mechanim on the end of the starter actually contains a small clutch. The clutch is designed to prevent starter damage by releasing if the starter gear stays engaged with the flywheel ring gear once the engine has started. Unfortunately these clutch assemblies can and do eventually wear out. Even though the starter spins and the solenoid extends the starter gear and engages the flywheel, the clutch assembly cannot transfer sufficient torque to turn the engine over. Exactly the situation you encountered.
Old Aug 27, 2009 | 05:41 PM
Weav's Vet's Avatar
Weav's Vet
Strange for sure. What are the chances of that happening at that particular moment when your dad tried to start the car.
Glad you got it fired back up and running.
Old Aug 27, 2009 | 05:50 PM
Snakecharmer383
Yes, very glad it fired up. Also in the mix that I didn't mention was the fact that I had a new clutch with alum. flywheel put in and only had about 75 miles on it before this happened. I have bad luck, no doubt about it and don't trust a bench test.
To Car is running again
