Can my chip burner remove the knock sensor code?
Old Feb 18, 2002 | 06:48 PM
Corey_68's Avatar
Corey_68
Default Can my chip burner remove the knock sensor code?
I'm getting Fast Chips to burn the chip for the 383. The engine is a '75 high nickel 4 bolt main that is replacing the late model '86. Now the '75 does not have the fitting for the knock sensor, can the chip burner delete it altogether??
Old Feb 18, 2002 | 06:58 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: Can my chip burner remove the knock sensor code? (Thad)
they could, but I wouldn't recommend it. You need to get a knock sensor on there somehow. With fuel injection it's very important, unless you want to run a timing setup that's very tame.
Old Feb 18, 2002 | 07:11 PM
bogus's Avatar
bogus
Default Re: Can my chip burner remove the knock sensor code? (Marcho Polo)
I agree with Marcho... try adapting a freeze plug...
To Can my chip burner remove the knock sensor code?
