Need expert help diagnosing miss
Old Sep 25, 2009 | 08:35 PM
MK 82's Avatar
MK 82
He was right about the wires but wrong about shutting down cylinders. A 95 with OBDI has no way of isolating missfire to a particular cylinder and thus no way of "shutting down" said cylinder.
Originally Posted by rnelson11
He said that if 2 are swapped that the computer will shut them down and it will still run.
The 2 that I was certain were right, 6 and 8, were swapped.
Old Sep 26, 2009 | 02:40 AM
devildog's Avatar
devildog
From: fighter pilots make movies, bomber pilots make history
INJECTORS
Check the resistance across each injector cold and hot. I do not know the resistance for your 91 (13 ohms???).
If you going to work on these C-4 buy a FSM (field service manual), otherwise you are guessing and throwing parts at a problem.
Joe
