350 TPI Missing at Idle....
Old Aug 31, 2009 | 12:00 PM
74L82AirRoadster's Avatar
74L82AirRoadster
Default 350 TPI Missing at Idle....
Hey all,
I have a 350 TPI in my 1988 IROC Z and I'm having an issue with it missing occasionally at idle. The car runs fine going down the road, but when it sits at a light in gear, I get the occasional miss.
I had this when I bought the car and replaced a bunch of parts. The last thing I did was replace the injectors about two months ago with Bosch III's from FIC and that seemed to fx the issue. Now its back again. Any ideas on what to check next? The car runs fine but its annoying sitting at a light. List of replaced parts and work performed:
MAF
plugs
wires
distributor
cap
rotor
PVC valve
injectors
all intake gaskets
cleaned IAC
set timing to 6 degrees
set TPS
FP regulator
fuel filter
Any help is appreciated!
Old Sep 1, 2009 | 08:42 AM
74L82AirRoadster
No one has any suggetions?
Old Sep 1, 2009 | 02:28 PM
ernie22golf's Avatar
ernie22golf
Default On your miss
Of course you'll want to check the throttle body and make sure it is very clean, make sure of all things the battery is good and connections good. Other than that you've done everything - will just have to recheck as you may have gotten a defective part along the way. Hope it helps some.
Old Sep 2, 2009 | 11:00 AM
Red 91's Avatar
Red 91
You could try blocking the wheels idle in drive pinpoint the cyl. that is missing, go from there
Old Sep 2, 2009 | 07:47 PM
ULTM8Z's Avatar
ULTM8Z
Ahhh, the dreaded idle misfire... I struggled for a few years with mine. I did all the same things you did trying to diagnose it. Turned out I was losing compression on the number 7 cylinder, found during a leak down test. Determined it was leaking through the rings. In a last ditch effort before I pulled the engine, I ran some Rislone compression repair and put it in the oil. Damned if it didn't solve the problem! I think I had sticking piston rings and this stuff freed them up. I put the additive in, ran the car for a couple hundred miles and the misfire just disappeared over time. This was a couple of years ago and hasn't been back since.
Like yours, the leak was just enough to notice it at idle (where the leak rate was a high proportion of the total incoming A/F mixture), but once I was up to speed it wasn't noticeable anymore.
Strongly suggest you run a leak down test on all your cylinders.
Old Sep 4, 2009 | 02:00 PM
74L82AirRoadster
Thanks for the ideas guys, I'm going to play around with it this weekend and see what I can come up with. Hopefully its something simple..........
Old Sep 4, 2009 | 03:11 PM
Square's Avatar
Square
Does the idle improve if you unplug the timing wire?
Old Sep 4, 2009 | 07:30 PM
74L82AirRoadster
Haven't tried that......I did check the timing and it was set at 6 degrees.
Old Sep 4, 2009 | 09:28 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
You can use the timing light on each of the wires one at a time, while its running and it may narrow down which cylinder its missing from.
I use the light and rev the engine by hand,holding the trigger light down and watch for gaps and misses in the light flashes.Real easy to do and works well.
Old Sep 10, 2009 | 04:22 PM
74L82AirRoadster
Ok guys, I haven't done it all but here's what I have done so far. I apologize for taking so long between posts, just been busy here.
Dropped the timing from 6 degrees to 4 and then 2. Seemed to help for a little while but now its back. Car was slightly pinging when I gave it heavy throttle at an observed 6 degrees so I thought maybe the balancer had slipped and my timing was excessive. Car was alot more sluggish with 2 degrees of timing. Also disconnected the timing wire with no change.
Ran a can of Seafoam through it. Did nothing.
Tried the timing light trick on each cylinder. When the car was stumbling or missing, all plugs seemed like they were firing correctly.
Throttle body is clean as I cleaned it all up when I did the injectors about 4k ago. All of this went away when I did the injectors and resealed the intake..........Maybe I have a bad injector?
Next thing will be the compression test, but I don't have a leakdown tester. I just haven't done that cause its such a job on one of these cars........
Going away this weekend, so maybe I can do it next weekend or at least one night during the week.
Old Oct 3, 2009 | 04:06 PM
74L82AirRoadster
So I finally got around to doing a compression test today. While pulling the plugs, this is what I found on the number 7 cylinder and its as far as I got. Any ideas as its obviously the cause of my miss.....
I was thinking of a cylinder head gasket myself.....
To 350 TPI Missing at Idle....
