c5 wheels on c4
Old Aug 31, 2009 | 12:25 PM
Red 91's Avatar
Red 91
Default c5 wheels on c4
would anyone know if c5 base wheels will fit a 91 base c4; any pics? thanks
Old Aug 31, 2009 | 12:32 PM
Calderone's Avatar
Calderone
Yes the will fit but you will need 1 inch spacers
im running them with no problem
Old Aug 31, 2009 | 01:14 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I know when my wife had a tire issue we used one of my spare stock wheel/tire combo to get her 2004 to the shop.
I'll be trying her old rears on my car to see if there are any issues. I need to get another set of track wheels and old C5 take offs are pretty inexpensive. If I can go 18" then my tire choices get a lot better as well.
Old Aug 31, 2009 | 02:18 PM
GKK's Avatar
GKK
Base C5 17x8.5 and 18x9.5 wheels are a direct fit on 88-96 C4 Vette's.
84-87 C4 Vette's require spacers.
Old Aug 31, 2009 | 02:19 PM
Calderone's Avatar
Calderone
AHHHHH you have a 91 ...stoopid me !
DIRECT FIT !
Old Aug 31, 2009 | 03:00 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I may go that route when I upgrade my front brakes
Old Sep 1, 2009 | 09:32 AM
Red 91's Avatar
Red 91
Thanks for the info, I wonder if the math is off in the covette info at the top of the forum. Thanks again!
Old Sep 2, 2009 | 07:12 PM
adamc's Avatar
adamc
Default yes
I have '99 wheels on my '94 with no spacers. Works fine.
Old Sep 2, 2009 | 07:13 PM
adamc's Avatar
adamc
Default lug bolts
but yow will need new lug bolts.
Old Sep 2, 2009 | 07:49 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Huh????
My wife's 2004 uses the same size lug nuts as my 92.
You may want to get matching lug nuts for any C5 rim you use. But you won't need to put in new Studs.
When I do it I'll use the same open lug nuts just because they will be track wheels only.
Old Sep 3, 2009 | 08:40 AM
Red 91's Avatar
Red 91
Thanks again all! I went ahead and bought 01 c5 base thinspokes. Now I am trying to find some reasonable hubcentric 10 mm spacers to position the rear wheels properly.
To c5 wheels on c4
