Diagnose Tick
Old Aug 31, 2009 | 10:02 PM
jimmers's Avatar
jimmers
Default Diagnose Tick
I have developed an engine tick that speeds up with rpm's. I originally thought it was my injectors, but now im second guessing myself.
I unplugged the two injectors that I thought were ticking, but the noise never went away. Now I assumed it was these two injectors because the pulse on them is way stronger then the others when touched. Any idea why the pulse is stronger on these two? Are they bad?
Now i'm thinking it might be the lifters. The tick is coming from the back of the engine on the drivers side. If I touch the valve covers I don't feel anything. I'm going to take the covers and take a look. Should everything be tight? Any sort of wiggle?
The engine was rebuilt 2 years ago. This was the first year that 5w30 oil has been used. For the break in I used 10w30. Could this be an issue? Should I still be using 10w30? There is about 3000km on the engine.
The car runs very strong, with no codes. The ticking is present right when the car is started and once it's warm. It never goes away. Any thoughts or ideas? Thanks!
Old Sep 1, 2009 | 09:22 AM
Red 91's Avatar
Red 91
Check to make sure it is not an exhaust leak at the manifold
Old Sep 1, 2009 | 11:57 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Buy yourself a mechanics stethoscope.
Old Sep 1, 2009 | 11:20 PM
jimmers's Avatar
jimmers
How can I determine this?
Old Sep 1, 2009 | 11:26 PM
jimmers's Avatar
jimmers
I used a screwdriver and started listening in different areas, but could not find the sound. I've never done this before, but I take it when using a screwdriver or stethoscpe the sound will really jump out?
The sound seems louder under the driver sides dash.
Would an exhaust leak make a ticking sound that followed rpm? Maybe that could explain the rich smell?
Old Sep 2, 2009 | 10:31 AM
Aardwolf's Avatar
Aardwolf
Mine had a tick when I bought it and I never could find the source. Till I changed out the heads, there was a washer stuck in the valve.
Look for carbon tracing to find an exhaust leak.
Old Sep 2, 2009 | 11:11 AM
0Paul Ruggeri
Former Vendor
Usually an exhaust leak will get quieter as the engine warms up.
Old Sep 2, 2009 | 11:18 AM
jmgtp's Avatar
jmgtp
Loose rocker arm maybe?...
http://forums.corvetteforum.com/c4-t...e-running.html
Old Sep 2, 2009 | 09:29 PM
jimmers's Avatar
jimmers
Well it turns out I had a loose header bolt. I tightened it up and the tick went away. I checked the other bolts and some were a bit loose. Does anyone have any tips on tightening the bolt closest to the passenger?
Thanks to everyone for their help!
Old Sep 2, 2009 | 10:38 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
That last one is easier to get to from the bottom.
Old Sep 3, 2009 | 08:36 AM
jimmers's Avatar
jimmers
I tried but I can't get a wrench or socket on it. I'll give it another go!
Old Sep 3, 2009 | 08:46 AM
Red 91's Avatar
Red 91
Possibly a 12 point wrench, or bend a wrench with a torch to fit.
Old Sep 3, 2009 | 09:52 AM
Midnight 85
Try a 1 inch allen bolt, the allen wrench might work better for you. I have Hedmans and that area is wide open on the bottom but yours may be different.
Old Sep 3, 2009 | 05:18 PM
jimmers's Avatar
jimmers
I've got Hooker headers and i can barely fit my hand in there. Thanks for the tip, I'll give it a try.
To Diagnose Tick
