Any aftermarket replacement for OptiSpark?
Old Feb 21, 2002 | 11:43 PM
arnold's Avatar
arnold
Default Re: Any aftermarket replacement for OptiSpark? (Tom Piper)
BTW Tom, Injineer (good man btw) is firing his CNP LS1 coils with a Motec,
which gets a good/accurate signal from the original opti. A little more
expensive this way, but a good crisp ignition none the less. Once you
have had CNP, you won't want to go back.
Old Feb 22, 2002 | 12:13 AM
GlockLT4's Avatar
GlockLT4
Default Re: Any aftermarket replacement for OptiSpark? (arnold)
I think the best alternative is coil packs of somekind. But I'm not sure how you're going to implement that. My best guess would be to look at the design of the LS1 since it uses coil packs.
Old Feb 22, 2002 | 02:18 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Any aftermarket replacement for OptiSpark? (Glock'94)
Jacob's Electronics did make an eliminator
Phil LT401 runs it.
Old Feb 22, 2002 | 09:59 AM
Rick93Z07's Avatar
Rick93Z07
Default Re: Any aftermarket replacement for OptiSpark? (BrianCunningham)
All the aftermarket solutions have had reliability issues too. The simplest solution is to seal the seams in the stock unit with permatex and add a factory '96 purge harness kit. The premature failure issues are effectively addressed using this strategy and the device should last 100K+ miles like the handful of owners who live in dry climates, don't wash their motor and keep the stock setup dry. The frustration and anti-LT1 sentiment stems from owners who keep "throwing" expensive Optisparks at their car without $17 worth of mods. I think GM should sell them in 12 packs for some people. I can dump a bucket of water on my sealed and purged '93 unit with zero concern.
Old Feb 22, 2002 | 10:59 AM
1991Z07's Avatar
1991Z07
Default Re: Any aftermarket replacement for OptiSpark? (bellmd)
I would think that some kind of crank-triggered magnetic pick-up system would work. Accel, Mallory and a few others have such systems available and have had them for years. It isn't a new idea.
More than likely it's what I'll be using on the new 427 SBC I'm building.
flubuyu2's Avatar
flubuyu2
Default Re: Any aftermarket replacement for OptiSpark? (jeepers10246)
hey looks like you did get the best deal I've ever seen,what did ya say? just call and let him know your a forum member?It looks as if I going to have some down time (because of opticrap)so going to do a bunch of stuff as well can jeff help with all vette parts?sorry so many questions .....thanx
Tony
P.S. if ya do not want to post reply(dont want to get jeff in trouble)E-mail FLUBUYU2@aol.com if ya think he can help me too!
Old Feb 22, 2002 | 03:30 PM
emoshn's Avatar
emoshn
Default Re: Any aftermarket replacement for OptiSpark? (flubuyu2)
I just did the job on my 92. Used the Feb 01 Corvette Fever article and made all those mods. Feel like I'm pretty watertight now and vented with GM harness kit. I like it. Good enough for little ol me.
