Polyurethane swaybar bushing question
Old Feb 19, 2002 | 01:57 PM
DanDman's Avatar
DanDman
Cruise-In III Veteran
Default Polyurethane swaybar bushing question
I'm thinking about changing to the polyurethane bushing on just my front and rear swaybar. Has anybody done this and is there a noticeable difference in the handling just changing the sway bar bushing only? Pro's and Con's please
96 coupe
Old Feb 19, 2002 | 04:12 PM
Dave's_88's Avatar
Dave's_88
Default Re: Polyurethane swaybar bushing question (DanDman)
I'm in the process of changing all of my bushings to polyurethane.
Pro's
- It's easy to do
- It's not that expensive
- I've heard, from members of the forum, that there is a noticeable difference
Con's
- Supposed increase in road noise
Old Feb 19, 2002 | 06:52 PM
John Row's Avatar
John Row
I replaced all the bushings with poly except the swaybar. It was recommended to leave it with the stock rubber to reduce the small bumps and road noise sometimes associated with the poly bushings. I like my setup a lot. No more hopping around on rough corners, stays straight on road with curvey rain cuts. Feels like it's on rails. No annoyingly jarring ride.
Cheers,
Old Feb 20, 2002 | 02:28 PM
silver & red CE's Avatar
silver & red CE
I did just the poly sway bar bushing/endlinks at the same time I was replacing the stock 26mm hollow/24 mm solid front and rear sway bars. Even with the stiffer 30mm solid front and 26mm solid rear sway bars I wasn't able to notice any increase noise, vibe, harshness. I was able to notice an increase in handling.
IMHO, poly bushings and bigger sway bars is a great mod, the best thing I did to my car, esp considering the cost is under $250.
Eric
Old Feb 21, 2002 | 07:09 PM
BBA's Avatar
BBA
I'm thinking about putting poly bushings on the front of my 87, since the rear is too stiff in the first place.
Old Feb 21, 2002 | 08:28 PM
BobMachus's Avatar
BobMachus
Default Re: Polyurethane swaybar bushing question (BBA)
I just did all the bushings except for the sway bars on my car. It is soooooo much better now. I am going to put Poly sway bar bushings in soon. Since my car is a vert, noise from new bushings is not gonna be a big deal.
Old Feb 21, 2002 | 10:04 PM
88-406's Avatar
88-406
St. Jude Donor '05
Hey I got a question for those of that have done the swaybars. Asume we're talking about the Doug Rippie kit, In regards to the front bar, what's the deal with the sleeve? Am I susposed to press it out of the old bar and reuse it in the new one?
Any help would be appreciated.
KM
Old Feb 21, 2002 | 10:21 PM
silver & red CE
Default Re: Polyurethane swaybar bushing question (88-406)
...what's the deal with the sleeve?
I pressed/wacked the sleeve out of the end of the swaybar, then drilled/torched the rubber bushing inside of the sleeve. The only thing I reused was the outer sleeve. Pressed the sleeve back into the new bar, then lubed the poly bushing and installed it.
Eric
Old Feb 22, 2002 | 02:28 AM
Grzldvt's Avatar
Grzldvt
Default Re: Polyurethane swaybar bushing question (silver & red CE)
I also changed all mine to Poly, and did the same for the sway bar, tapped the metal shell out of the bar, replaced the bushing and tapped it back in.
Old Feb 22, 2002 | 07:05 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Eric
:yesnod: Leave the outer shell in the sway bar and replace the bushing and the inner sleeve that goes inside the bushing.
Old Feb 23, 2002 | 10:40 AM
jshope's Avatar
jshope
Default Re: Polyurethane swaybar bushing question (Red 90 L98 Coupe)
I did not do the sway bar, but I did replace the majority of the back end with poly.
The control arms squeak now when going over bumps. Does anyone know how to eliminate this squeak?
Old Feb 23, 2002 | 11:30 AM
Bill Reid's Avatar
Bill Reid
Default Re: Polyurethane swaybar bushing question (jshope)
I replaced ALL bushings in the car with Poly. Bone jarring? You bet... but wouldn't think its any worse than stock. Early C4's with Z51 are stiff already :yesnod:
Old Feb 23, 2002 | 11:35 AM
The Dingo's Avatar
The Dingo
My first guess is that you may not have enough grease on the bushing contact surfaces and on the outside surface of the inner sleeves. I'd try regreasing them, don't be too sparing with the stuff.
Old Feb 23, 2002 | 07:35 PM
silver & red CE
It's not that hard to pull the entire bushing w/sleeve, it's real hard to remove the rubber from the sleeve when it's attached to a 15lb bar :cheers:
To Polyurethane swaybar bushing question
