best way to refill cooling system
Old Sep 2, 2009 | 08:45 PM
looney1316's Avatar
looney1316
Default best way to refill cooling system
all but done changing hoses and other stuff on 90 vette what is the best way to make sure all the air is out of the system
Old Sep 2, 2009 | 10:27 PM
machinegunminky's Avatar
machinegunminky
Loosen rad cap
Start motor and bring up to a temp that will open stat
Remove rad cap
Reach over and hold throttle around 2000 rpm
While holding throttle, fill rad with coolant
Put rad cap on
Release throttle
Old Sep 3, 2009 | 01:22 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
aka: packing
http://forums.corvetteforum.com/c4-t...d-packing.html
Old Sep 3, 2009 | 11:18 AM
josephf31's Avatar
josephf31
Default If
Originally Posted by machinegunminky
Loosen rad cap
Remove rad cap
Put rad cap on
Release throttle
you haven't done so already drill one or two small (3/16" or so) holes in the rim of the thermostat too.
To best way to refill cooling system
