Weird opti problem
Old Sep 3, 2009 | 12:38 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Weird opti problem
On my way to run errands yesterday, the car died on me. Looked under the hood and I had tighened the radiator hose on the pass. side all the way and it was leaking pretty bad.
Here is the weird part, I had put RTV all around the opti when I installed it and from what I could tell, the coolant leaked over the front of the opti and not directly on top and when I 1st pulled over the car would restart and backfire, but after it sat for a few minutes it would not start at all.
Got the car home and tried to start it this morning and no go, I have two questions.
1) Could spray alone get into a supposedly sealed opti and cause this or did fluid get into the connector and create a short between a couple of wires?
2) Should I give it a day and see if it dries out and runs or tear it down( don't want to, just changed wires and WP) and clean it out?
Thanks guys!!
Old Sep 3, 2009 | 12:55 PM
runner140*'s Avatar
runner140*
If you have a shrink insulation heat gun use it to heat up and dry out the area on, around and in the Opti. Use a hair dryer if you don't have a heat gun. Its worth a try.
Old Sep 3, 2009 | 12:56 PM
Locke's Avatar
Locke
I'd rent or borrow a code tester and see if the Opti was throwing the code to be the cause. It might dry out, put a drop light down near it to make some heat. Just don't set it on something plastic that it can hurt. There's a lot of difference between 100 degrees with the bulb near things and melting with the shield on something.
Heat gun is a great idea; careful though,they will melt plastic. The wife has not forgiven me for the damage I did defrosting the freezer.....
Good luck but it sounds like you're about to pull an Opti.
Locke
Old Sep 3, 2009 | 01:01 PM
Locke's Avatar
Locke
Yours is a known case of fluid neer the Opti but the last one I looked at that just backfired a few times then refused to start was a case of the 'rotor screws' just backing out.
I've been told that is the common death cause. They need to be pulled apart and the screws epoxied in place or a verry small machine screw and lock nut put in place.
Wish I'd know that before putting my last one in my car!
Locke
Old Sep 3, 2009 | 01:51 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I thought screws backing out were the 1st gen MSD opti's?
Mine is a Delphi and I will use a hairdrier, thanks for the quick responses!!
Old Sep 3, 2009 | 02:31 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thought my leak was caused by a bad hose, well after examining the T housing it wasn't. My housing is pitted and has a lot of build up, especially the underside of the snout, so I would say if you see coolant under your car, it might not be the WP.
Old Sep 3, 2009 | 03:35 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
You can bring the codes up on the dash
http://s242.photobucket.com/albums/f...m/ccm%20codes/
Old Sep 4, 2009 | 10:12 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
No codes, but it runs now for about 5 minutes and then just dies.
Could getting the opti wet put a strain on the ICM and caused this?
Cause I have read other peoples threads about this and it always seems to be the ICM.
Old Sep 4, 2009 | 01:56 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
It seems to die when temp gets to 175ish degrees, I would think it would have burned off the coolant at that temp?
Old Sep 4, 2009 | 02:05 PM
BrianCunningham
sounds more like the ICM to me
how old are the wires?
Old Sep 4, 2009 | 02:22 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I just put them on, that is what started this mess.
I am thinking ICM also, they don't seem to last long, just put this one one about 2-3 yrs ago.
Old Sep 4, 2009 | 04:35 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
One of the things I did when I replaced my ICM and coil (based on a suggestion here) I put several washers between the head and the plate for the ICM/Coil. This seems to have helped the ICM last a little longer.
To Weird opti problem
