Dyna Spark or GM opti
Old Sep 4, 2009 | 05:06 AM
Weav's Vet's Avatar
Weav's Vet
Default Dyna Spark or GM opti
I know it, another opti related question but I need advice on which one to get. I don't want the MSD so please don't mention it. The Accell is junk. I just can't decide whether to pay the 600.00 for the Dynaspark ot take a chance with the GM for about half that. I know a LS1 ignition system would be nice but I can't go there.
What would you guys do?
Old Sep 4, 2009 | 05:48 AM
96redvette's Avatar
96redvette
I am currently having issues with Dynaspark. I did buy mine remanufactured from them, so not sure if that means anything or not, but I'm not a happy customer with them at the moment. They seem to be trying to make it right, but my car has now been down for almost 2 weeks because of this.
My other choice was the MSD, why don't you like the MSD...just curious if there was something I didn't know.
Old Sep 4, 2009 | 05:52 AM
Weav's Vet's Avatar
Weav's Vet
I've read of high RPM issues among other things. I swear, I think all of them have some kind of issue.
Old Sep 4, 2009 | 05:54 AM
Weav's Vet's Avatar
Weav's Vet
I hope you get yours worked out.
I haven't read of to many problems with the dynaspark.
Old Sep 4, 2009 | 07:03 AM
lt1396corvette's Avatar
lt1396corvette
Default optispark
I don't understand why so many people have problems with the optispark.I have a 94 vette and never had a optispark go bad on me.I did put in the vented optispark when i did a cam change.I would buy the GM optispark JMO. THANKS JEFF
Old Sep 4, 2009 | 08:22 AM
Strick's Avatar
Strick
ditto
OEM opti installed several years ago along with an electric water pump so no anti freeze can leak on the opti.
Old Sep 4, 2009 | 09:15 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Is your current optispark vented?
If so then an OEM replacement will be fine.
Not vented like my 92 was - aftermarket Dynaspark. Caveat - I think I got one of the last ones from before the company was bought/sold last. Its been good, other folks have had issues since them. I'm not sure what happened to the company.
If I was spending my money on an opti today I would get an MSD, open it and fix the loose screws, re seal it, etc.
Old Sep 4, 2009 | 10:58 AM
aboatguy's Avatar
aboatguy
Vented OEM OPTIs are reliable and the one on my vette handles jaunts to 6500+ rpm great....
if you have a 95 or 96 OEM opt .....If not......for the cost of the aftermakarket options if I had an early Lt1 I'd do a vented opti conversion
Mike
Old Sep 4, 2009 | 11:22 AM
blue94's Avatar
blue94
Had problems with the old version on my 94 and replaced it with a vented (new) opti 3 years ago... no more issues
Old Sep 4, 2009 | 11:37 AM
mcnulty95's Avatar
mcnulty95
Mine was replaced about 5 years ago with OEM after the water pump let loose. I had 40k on the car when it was replaced and have 60k on her now.
Old Sep 4, 2009 | 12:32 PM
Weav's Vet's Avatar
Weav's Vet
Thanks for all the replies. Sounds like I'll give GM a go. Mine isn't bad I'm just replacing it in this cam swap process. The car is a '96. Thanks again!
Old Sep 4, 2009 | 12:38 PM
aboatguy's Avatar
aboatguy
Watch out for cheap chinese counterfeits, and shoddy rebuilt units...
I've had good luck with the partsladi however, looks like others haven't..
Just ensure you are buying from someone thats "licensed?" by GM to sell their parts and you should be good to go.
Here's a screen shot of 6800 rpm shift (on the street not dyno or track)
Old Sep 4, 2009 | 01:27 PM
reoch999's Avatar
reoch999
I know you said not to mention the MSD opti, but since you said yours is working fine... Have you seen what MSD calls a cap and rotor kit? It replaces pretty much everything plastic and all the high voltage contacts, but uses the original unit's metal and optical wheel/sensor. But the best part, if you have an early style like mine, is it comes with tubes and fittings to run to the intake duct and to tap into manifold vac to make it a vented unit. Since mine was working fine when I pulled the engine out, I decided to go that route and so far (2 months later) I'm happy with it. It spins to 6400 where my rev limiter is set without any problem. I'm still on a stock bottom end, so I don't want to go much higher than that.
For what it's worth, I'm curious what you've heard about high RPM issues with MSD. I've only heard of that with high mileage stock optis. I know of at least 3 engines (one Impala, one Caprice wagon, one Camaro) I have seen personally that spin past 6500 with the whole MSD opti without trouble.
Old Sep 4, 2009 | 01:35 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Dynacrap is no longer a supporting Vendor so, hopefully this post stays.
I've PM few of you and my experience with the Dynaspark was awful. It was the only thing I did to the Vette and there were detonation after detonation/ping/bang/you name it. I was about to deploy to Iraq, I did not have the time to remove it put it back in a box a get my money back so I got screwed BAD. I bought the MSD and all problems went away. Other members claim to be satisfied with it others including me were not so lucky.
I know soon or later somebody will invent a great replacement and affordable for us to upgrade from this nightmare.
Old Sep 4, 2009 | 03:10 PM
Weav's Vet's Avatar
Weav's Vet
Thanks reoch, almost two years ago right after I bought the car I had a mechanic replace the cap and rotor on the OE unit plus fix a bunch of oil leaks etc,etc. As far as I know the one that's in there is fine. I'm just trying to dodge some trouble down the road by replacing it while I'm in that far to the front of the engine. I'll check into the MSD cap and rotor. Do you know who is making the guts to the GM units now? It used to be Mitsubishi but I think they got out of it. The ones they made held up pretty good from what I've read.
Sorry I can't remember exactly where I read that about the misfire at high rpm. It had to be either here or LS1 or Gurus. I wonder though how many of these problems are installation related and not the units fault.
Old Sep 4, 2009 | 03:11 PM
Weav's Vet's Avatar
Weav's Vet
I didn't realize this Pete, thanks for the heads up!
Old Sep 4, 2009 | 03:22 PM
Weav's Vet's Avatar
Weav's Vet
It's just about a crap shoot isn't it. Good idea about the license. I'll be sure to check that out.
To Dyna Spark or GM opti
Old Sep 4, 2009 | 03:28 PM
skybolt31's Avatar
skybolt31
Seems like the opti experiece is all over the place. A little while back, there was a poll on the MSD opti,
http://forums.corvetteforum.com/c4-t...opti-poll.html
73% said no problems, the rest were about split between minor and major problems. I think many looked at the Dynaspark and then the MSD as that great replacement opti, but I don't think either has convinced me that they are better than stock, at least better than the stock later vented units.
When I replaced mine (only because I was doing the water pump) I went with a stock unit, if I had an earlier car, it would have been a tougher decision. One thing that I wish I did would have been to put a hose in the weep hole on the water pump and run it to a small container that I could check periodically. I think that coolant and opti bearings are a bad mix.
Old Sep 4, 2009 | 06:33 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I have had my fair share of Optis issues, Dynaspark and OEM GM. Problems were with, IMHO install. When a new cam, the dowel pin length may be different and gasket thickness cause the Opti to not line up properly. Dynaspark was very clear on install instructions.
Lesson learned, be **** about the install, go 95 and newer and by OEM.
Old Sep 4, 2009 | 08:28 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
GM on mine and no issues, I have never had an MSD anything work for very long. Probably great stuff just not for me
