What A/C pressures should be
Old Sep 4, 2009 | 07:42 PM
scotth48's Avatar
scotth48
Default What A/C pressures should be
What should the pressures be on the high and low side. My '93 Ruby had been converted to 134 last year. I put a new switch in this spring as clutch would not engage and fan would not come on. Now it is not running cold at all. My outside temp is not registering either about 44 degrees higher than actual outside temp. not sure if both problems are related.
Old Sep 4, 2009 | 08:20 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Around 35 on the low side, 225 on the high side.
Old Sep 5, 2009 | 06:19 AM
scotth48's Avatar
scotth48
To What A/C pressures should be
