Diff ratio?
Old Sep 6, 2009 | 02:00 AM
Phantom_Vette1's Avatar
Phantom_Vette1
Default Diff ratio?
Hi
i am curious as to whether going from a 2.59:1 diff to say a 3.07:1, or 3.45, or 3.57 would be a huge difference in both acceleration and fuel consumption!
i know of course the shorter the gear ie 3.57:1 will be fast but use the most fuel!
but i am curious as to what is a good medium?
i was thinking of going 3.07:1, but would 3.45:1 be better without alot more fuel usage?
i have seen a 3.07 diff for $365 AUD which i think is pretty cheap!
btw i am in Western Australia!, so it is hard for me to get stuff from the US as they don't want to ship to us else i would!
thanks
Old Sep 6, 2009 | 02:29 AM
pologreen1's Avatar
pologreen1
I have had 3.07's and now 2.59's
the difference is a sports car, compared to a 70's car with a v8.
i hate the 2.59's so I bought 3.75's, not installed yet, but I can garuntee you and me I will love them.
I have driven one with 3.54's and it was more fun, but never enough for me.
WVZR-1's Avatar
WVZR-1
The 3.07 would be an "ideal" swap for many reasons! Availability and price first of all. Based on your location and if the rear is "sound" it's a good maybe "great" find. You would certainly enjoy the "SOTP" experience and economy wouldn't suffer substantially if you kept "your foot out of it"!
Old Sep 6, 2009 | 02:37 AM
Phantom_Vette1
ok sounds like a good swap then up to 3.07 without hurting the fuel economy too much!
i know we always want more, but would going that bit more like 3.54 be better option in the long run? i would hate to ge the 3.07 and then want more later!
are there 3.45 gears available?
Old Sep 6, 2009 | 02:46 AM
WVZR-1's Avatar
WVZR-1
Many of the ratio's that are "higher" numerically are done with a "thicker" ring gear which would require the use of your 2.59 carrier. Richmond Gear comes to mind for this type of build. You would need to just be cautious when buying a gear kit for a "higher" numerically gear.
I doubt you'll be disappointed with a 3.07 build!
Old Sep 6, 2009 | 03:56 AM
CorvAdel's Avatar
CorvAdel
2.59 to 3.57 would be a relatively "huge" difference. The acceleration would be quite impressive.
If you do many country miles, fuel costs will be noticeable with the higher gears. Around town it won't be so bad...in 80kay zones your trans will jump into o'drive and rpm's drop nicely. In 100kph or higher driving, even in o'drive, the engine is going to spin fairly high, affecting fuel economy.
I have had 2.59's, 2.73's and am now running 3.07 and am loving it....wakens the car up nicely , yet doesn't rev high on the open road...so still has good fuel economy.
Lastly, you can't get too fussy in Oz..! That 3.07 for $365 is a steal...you won't get anything for $365 to fit to your car that will offer the performance gains that will come from that rear gear...
Hope this helps your decision, unless bux don't matter, in which case bigger will be faster and more expensive, but a whole lotta fun...IMO
Old Sep 6, 2009 | 05:00 AM
rodj's Avatar
rodj
2000rpm @ 110kph with 3.07's in O/d (A4)
Old Sep 6, 2009 | 01:37 PM
vette079's Avatar
vette079
That´s cool, I´m in Sweden and my 91 A4 with 2,59 runs 2000 rpm´s (on tach) at 120 kph/75 mph.
Maybe the km´s shrink when colder...
Or my tach is off, who knows...
Edit, reread and saw 3.07´s in prev post...
Time to start reading posts I guess...
Or isn´t it more of a difference then 10 km´s at same rpm???
Anyone know of a way to calculate something like this???
Old Sep 6, 2009 | 01:53 PM
92ZR1WANNABE's Avatar
92ZR1WANNABE
Originally Posted by Phantom_Vette1
Hi
thanks
I would have to say when you compare price / fuel mileage / acceleration improvement you can't go wrong with throwing the 2.59s in the trash and going with a used 3.07 diff.
I did the swap a year ago and it pretty much feels like a totally different car.
It will depend however on what motor you have in your car as well. Mine is a LT1 , if yours is not then what I said above may not apply.
Old Sep 6, 2009 | 01:59 PM
383tpimachine's Avatar
383tpimachine
at 71mph my car just changes from 20xxrpm to 21xxrpm with 3.07 and OD.
2000rpm with 2.59 at 75 seem high unless they are VERY low in the 20xx
Ill be going with 3.54 gears when i swap to D44 and built 700r4
need it to withstand a 427 stroked 400 later down the road with alot of nitrous. Plan ahead
Old Sep 6, 2009 | 02:03 PM
tblt44's Avatar
tblt44
I'm glad mine came with 3.07 very happy with it.maybe wish I had 3.57.I'ts never fast enogh off the line.
Old Sep 6, 2009 | 02:04 PM
vette079's Avatar
vette079
I guess I´ll have to double check the tach rpm with the digi read out on the C68 to be sure, it´s not impossible that my tach reads to high.
Old Sep 6, 2009 | 02:22 PM
383tpimachine
Im installing a mini analog tach in my vent so I can see exactly where im at. This is my biggest issue with the Digi dash.
Old Sep 6, 2009 | 02:32 PM
aboatguy's Avatar
aboatguy
Best calculator ive found and I've been using it for YEARS http://www.f-body.org/gears/
I use the 93-97 A4 as a base line (same tranny I just enter my gear ratio and tires)
Old Sep 6, 2009 | 04:31 PM
92ZR1WANNABE
Very nice calculator!
Wow you guys with 2.59s are good for 240mph in OD at 5700RPM .. in your C4
O to have the road , horsepower , tires , and nuts to do that
Old Sep 18, 2009 | 02:48 PM
vette079's Avatar
vette079
Well, checked it and it´s doing 2000 rpm at 120 km/74-75 mph.
Checked it through the digital read out in the AC controller/display.
At 2000 rpm on the analog gauge it showed 79-80 on the C68 display.
Makes 2000 rpm if I have to believe the calculation in the FSM.
Value on display multiplied with 25.
Old Sep 19, 2009 | 03:23 PM
Phantom_Vette1
Sorry i have not been on for awhile!
thanks for all the comments, i think i will eventually go with the 3.07 gears! when money allows
most of my driving is around the 60-70km/h speeds, while every now and then i get up to 90 and 100km/h!
I have a 90 model so an L98 engine! which has good low down torque anyway, so it should be alot better with that diff!
Do you guys drive in D or keep it so it stays in 3rd(auto cars of course)?
the car shop guy i bought it from said to drive it in 3rd and only select O/D when going 80 plus! i assume as it keeps the revs up and doesn't bog down!
Old Sep 19, 2009 | 03:59 PM
vette079's Avatar
vette079
It´s not a bad thing to do as the car shop guy says.
Don´t know how to explain it technically, but read about a similar thing here on the forum.
I drive it that way too.
To Diff ratio?
