96 LT4 coolant leak
Old Sep 6, 2009 | 02:36 PM
DSchaefe's Avatar
DSchaefe
Default 96 LT4 coolant leak
Seems to be coming from right around the pulleys and leaking down over the spring/crossmember - though I could not trace the exact source. I parked the car and 10 minutes later I have a puddle. No coolant/wetness around the upper or lower hoses or Tstat, which are all new in 07. Nothing around the radiator or overflow either.
Water Pump is original and that is my suspect - just want to be sure before I start tearing stuff up. Car runs fine otherwise and is still holing normal water temp. Opti is original too and like I said - running fine.
Thoughts from the crowd?
Old Sep 6, 2009 | 03:03 PM
LTxDave's Avatar
LTxDave
Sounds like the bearing is going bad and you're loosing coolant from the weep hole. Time for a new water pump.
Old Sep 6, 2009 | 03:16 PM
94z07fx3's Avatar
94z07fx3
Wrap the suspects with toilet paper and run the car briefly.
Old Sep 6, 2009 | 06:59 PM
runner140*'s Avatar
runner140*
A quick test is go to an auto parts store, have them put a radiator cap tester on and put 15 lbs in and see where it leaks from.
Old Sep 6, 2009 | 09:14 PM
STL94LT1's Avatar
STL94LT1
Check the weep hole, I bet it's wet.
Old Sep 6, 2009 | 09:47 PM
RichS's Avatar
RichS
A 3rd vote.
Old Sep 6, 2009 | 10:03 PM
tblt44's Avatar
tblt44
Replace it if it's the pump before you have to replace your opti
To 96 LT4 coolant leak
