Redline Shockproof info....
Old Feb 19, 2002 | 09:09 PM
RichS's Avatar
RichS
Default Redline Shockproof info....
I put the Redline lightweight oil in the GS over the winter but didn't drive it. After all the debate about it a few days ago I e-mailed Redline and asked them about it. Here is the reply from them with my question.
> I just put your Light weight ShockProof oil in my 96 GrandSport
>Corvette. My question is do I need to add the Friction Modifier to the
>rear? If so how much? The Differential is stock except for adding 4:10
>gears about 8 months ago. I chose the Shockproof oil since I drag race
>at about 10-15 events a year.
>Thanks for your time,
>Rich Shuleski
In a street application I would recommend the Red Line 75W90, it
contains 5% friction modifier and would be suitable for all around
use as well as drag racing.
In a drag race car that is being trailer to the track, the ShockProof
Heavy would be my recommendation, it contains 3% friction modifier
and will give a little more lock up.
The ShockProof lubes are primarily used for racing and speciality
applications and aren't recommended for all around street use, our
other lubes are better suited to the broader range of temperatures
encountered on the street.
Thank you for your interest in Red Line Oil.
I wish they stated this in the add on their site. Now I have to drain it again. But I'd rather drain it than blow it up :D :D
Old Feb 20, 2002 | 02:10 PM
silver & red CE's Avatar
silver & red CE
Default Re: Redline Shockproof info.... (RichS)
Rich,
I just had that gear set you sold me installed. Since my 96 only has 20K miles, all I needed was the gear and install kit. Thanks.
Back to the point, I installed a drain plug in my 44 case, and when I fill the diff back up, I'll use Mobil1 and a bottle of friction modifier.
Eric
[Modified by silver & red CE, 12:10 PM 2/20/2002]
Old Feb 20, 2002 | 02:14 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
That's a different story than what I got several years ago. I asked them for a recommendation for my 95 Firebird (LT1) 6 speed, and told them it was a daily driver with lots of drag strip, autox, and roadcourse use as well. They recommended the shockproof heavy. I put it in and ran it for 30k miles with no problems.
To Redline Shockproof info....
