COOLANT SMELL INSIDE THE 92!!!!
Feb 19, 2002 | 09:44 PM
Anyone have a detailed proceedure on replacing the heater core?
I have a Haynes manual but just like everything in it (remove part
replace part) not very detailed. I have a GM manual for the 86, but
have not found one for the 92. :eek:
Feb 19, 2002 | 10:17 PM
Re: COOLANT SMELL INSIDE THE 92!!!! (CEEFOUR86)
Anyone? :confused:
Feb 19, 2002 | 10:27 PM
I will have to check the book...
you may want to get a helms manual...
http://www.helminc.com
Feb 19, 2002 | 11:03 PM
might want to disconnect the heater core before it decides to dump coolant all over the passenger side floorboard, at least thats what mine did.
Feb 20, 2002 | 01:37 PM
Re: COOLANT SMELL INSIDE THE 92!!!! (C4Fetish)
Thanks for for the input guys, I am going to bypass the core before
I drive it again. I just put new carpet in and don't want it soaked with
coolant. :nonod:
Feb 20, 2002 | 01:52 PM
I have the helms manuals for a 92. Let me check on my lunch hour and if gives more than remove/replace, I'll copy the pages and illustrations and Fax them to you if you provide your fax number.
Feb 20, 2002 | 02:38 PM
I've got the genuine GM factory service manauls. I can check on them for you, but it'll be after I get home, around 5 or so.
Feb 20, 2002 | 03:32 PM
I CAN FAX THE PAGES FROM THE 1992 SHOP MANUALS IF YOU SUPPLY A FAX #
Feb 20, 2002 | 09:21 PM
Re: COOLANT SMELL INSIDE THE 92!!!! (ittlfly)
Thanks guys, but I don't have fax here at home (although I need one). Can the pages be scanned and e-mailed?
Feb 20, 2002 | 10:49 PM
Cruise-In II Veteran
Just take the dash out!!!!!!!!
That's what I DID!!!!!!!
It sucks,take your time!
Matt :yesnod: :yesnod:
