steering wheel height adjustment
Old Sep 7, 2009 | 01:24 PM
superc4's Avatar
superc4
Default steering wheel height adjustment
In a 1990, how do you adjust thee steering wheel height?
Old Sep 7, 2009 | 01:40 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Pull on the tilt lever and move the wheel to where you like it...then release the tilt lever? That's what I do.
Old Sep 7, 2009 | 03:31 PM
superc4's Avatar
superc4
Where is the tilt lever?
Old Sep 7, 2009 | 03:39 PM
93_vette's Avatar
93_vette
It's on the left side of the steering column. It's really short, about 4 to 5 inches and behind the turn signal.
Old Sep 7, 2009 | 04:27 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
It may have fallen out, tilt lever that is. Mine does occasionally, as it needs to be put in with a little loctite and love.
The tach is pointing at it
Old Sep 7, 2009 | 04:28 PM
Hooked on Vettes's Avatar
Hooked on Vettes
84-89 had the tilt and telescoping steering wheel columns.
90-96 only had the tilt wheel feature. No telescoping feature probably because 90-96 steering columns had air bags.
To steering wheel height adjustment
