Dyno numbers?
Old Sep 7, 2009 | 03:13 PM
thomasev's Avatar
thomasev
Default Dyno numbers?
I dynoed my standard Lt1 (93 mod) before the mods and it did about 250 rwhp (before any changes). The changes I`ve done are:
* comp cam 07-503-8 (Xtreme Energy series)
* new valve springs & retainers (matching springs to new cam)
* new Bosch design III injectors (from FIC) - 32 lb
* new tune from pcmforless.com
* Melrose longtube headers
* BB-tri flow 3" exhaust...
Just installed new chip today, and only did a short testride to check chip (so far so good)..
Anyone done a dyno with similar setup? Don´t know what to expect, but would like to see close to 300 rwhp...
Old Sep 7, 2009 | 03:35 PM
95wht6spd's Avatar
95wht6spd
don't know what cam specs are for yours, but a friend did a Hotcam, longtubes, tune on his Auto Z28 LT1 and hit 300rwhp, so I would think your would be at least this and probably more since you have a manual, and the cam is probably larger, & better exhaust.
Old Sep 7, 2009 | 04:02 PM
Weav's Vet's Avatar
Weav's Vet
You should hit 300. I pulled 303 rwhp with no cam and bolt ons. My base was 269 rwhp with a stock pcm.
Old Sep 7, 2009 | 04:23 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I agree, my 93 with 1.6 RR, and Flowmaster catback auto did 295 with a Hypercrap chip.
Something isnt right.
Who adjusted your rockers? And did Alvin tune it for the injectors and Long Tubes?
Old Sep 7, 2009 | 07:14 PM
92ZR1WANNABE's Avatar
92ZR1WANNABE
Does that baseline seem low?
My 92 planted 278rwhp , only mods at the time were corsa catbacks and the SLP Triple claw intake............... through a auto ................ with 124k miles on the clock.
Old Sep 7, 2009 | 09:31 PM
MrNuke's Avatar
MrNuke
'92s seem to always dyno more stock than other LT1's.
With a set of Borla Mufflers (not a full exhaust) , K&N and a chip I programmed, mine did what my sig says.
Old Sep 8, 2009 | 05:36 AM
93 ragtop's Avatar
93 ragtop
what kind of dyno did you use?
Old Sep 8, 2009 | 06:56 AM
thomasev's Avatar
thomasev
Default Before mods..
It's probably not clearly enough in first message (I'm not native english speaking guy).. the 250 rwhp was standard LT1 BEFORE any of listed mods.. I'm just interested to know if anybody has a dyno of his/her LT1 with similar mods, and what I should expect to see next time I will do another dyno run...
I hope to see 300+ rwhp...
Old Sep 8, 2009 | 08:35 AM
MrNuke's Avatar
MrNuke
With those mods, you BETTER be over 300RWHP.
Old Sep 8, 2009 | 10:26 PM
resipsa's Avatar
resipsa
My 95 LT1 6 speed 3:45:
Stock:
? rwhp ? rwtq
13.6x @103-105 (street tires/mid 80s)
LT Headers/random cats/corsa/PCMForLess tune/K&N filter element:
290 rwhp 320 rwtq
13.3x @105-106 (street tires/low 90s)
13.1x @106-107 (drag radials/mid 80s)
12.6x @108-109+(drag radials/mid 40s)
same as above plus XFI CC 466 cam 218/224 .570/.565 113 LSA, beehives, 1.6 rr, updated PCMForLess tune, open top filter housing:
322 rwhp 335 rwtq
13.1x @108-109 (street tires/low 70s)
To Dyno numbers?
