wieand stealth ram
Old Sep 8, 2009 | 11:40 PM
355flvette's Avatar
355flvette
Default wieand stealth ram
Has anyone tried one of the tpi manifolds. I did a search on here and have found anything. Thanks in advance. Theres a bunch of helpful stuff on here!!!
Old Sep 8, 2009 | 11:54 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-t...r-numbers.html
http://forums.corvetteforum.com/c4-t...76294-hsr.html
http://forums.corvetteforum.com/c4-t...-hsr-dyno.html
Old Sep 8, 2009 | 11:57 PM
bowtie350_428's Avatar
bowtie350_428
Same thing as a HSR (Holley Stealth Ram). It doesn't fit under the stock hood.
Old Sep 9, 2009 | 04:23 AM
rodj's Avatar
rodj
But this one will
http://www.usmracer.com/Holly-Stealt...it_p_2694.html
Old Sep 9, 2009 | 07:24 AM
355flvette's Avatar
355flvette
If they really are the same why is one $350 Wieand versus $900 Holley???? Will the wieand take all the stock injectors and all that?
Old Sep 9, 2009 | 09:00 AM
rodj's Avatar
rodj
The only thing off a L98 that will fit is the injectors. HSR requires different fuel rails and regulator
The Weiand /Holley setup ready to run is $560
http://www.summitracing.com/parts/WND-7540/
http://www.summitracing.com/parts/HLY-534-186/
The one in the link above has been specially modified to clear a C4 hood which the out of the box HSR doesn'thense the cost difference.
Old Sep 9, 2009 | 08:02 PM
355flvette's Avatar
355flvette
I thought the thottle body would fit? Can the stock fuel rail be modified to work? How much is the hood clerance anyways?
Old Sep 9, 2009 | 10:49 PM
rodj's Avatar
rodj
It does , you asked about intakes ; not TB's
No
There is no clearance on a C4 hood; the stock HSR is too tall unless you run a scoop
To wieand stealth ram
