would changing to a super ram help?
Old Sep 9, 2009 | 01:10 PM
c4mo's Avatar
c4mo
Default would changing to a super ram help?
I've got a 85 with the following mods
org. short block w/ 10.38.1 true compression w/ 64 cc heads
World product sportmans II 200cc heads w/ a good 5 angle valve job
lunati voodoo 60101 .454/.468 213/219 108 lca 112 lsa
edelbrock base cnc to 1205 gasket to fit the heads
tpis runners and ported plenum
hedman 1 5/8 headers w/ full 2.5 dual exhaust
8* timing 48psi fuel pressure
3.07 gears
transgo shift kit
shifting at 5200 rpm manually
With this combo ive made one run, stopped because of rain, running 8.68 at 80.38 with a tune not optimized yet. The problem is spinning will the super ram cure this and or made it faster or slower, i already have the sr runners and plenum so all the cost is gaskets. Thanks for any help.
Old Sep 9, 2009 | 01:22 PM
cumbercr's Avatar
cumbercr
My guess is that the SR will move your power band up 500 RPM. You may lose a little torque on the bottom end, but it sounds like you're having trouble hooking up anyway.
Old Sep 9, 2009 | 01:24 PM
Calderone's Avatar
Calderone
If you already have it ...buy the damn gaskets and go for it !!!!
Gaskets are around $ 37.00
Let us know ! many of us would love to see your review !
Old Sep 9, 2009 | 01:27 PM
383vett's Avatar
383vett
Go for the SR. Major torque throughout.
To would changing to a super ram help?
