1993 Central Control Module
Old Sep 9, 2009 | 01:59 PM
John James's Avatar
John James
1st Gear
Default 1993 Central Control Module
I have a '93 convertable and have pulled codes 31, 33, 35, 37, 41 and 54 from the CCM (in parts books the Body Control Module) The wiring has been checked and double checked by my mechanic. The solution appears to be to replace the CCM. Slight problem, the dealer, GM, and delco while theyu have a part # can not get this part. Is any availablke anywhere? Used? Can the security system be turned off as (code 54) the security system controlled by the CCM has turned off the fuel injectors rendering the car undriveable? Is there any other way to make the car run? I can fix anything mechanical, computers are not on my list. Appreciate any help, Thanks.
Old Sep 9, 2009 | 02:04 PM
toptechx6's Avatar
toptechx6
If you are sure you need the CCM I have been told forum vendor vette2vette can get them rebuilt, hope that helps.
http://www.vette2vette.com/
