Bumper mount frame damaged
Old Sep 10, 2009 | 10:37 PM
vettecrazy88's Avatar
vettecrazy88
Default Bumper mount frame damaged
For 88 coupe.
Removing bumper for paint and noticed the mounting plate is bent from previous accident.
How hard is it to replace. Just bolts or does it require welding?
Referring to part circled in red in attachement.
Appeciate the help.
Old Sep 10, 2009 | 11:00 PM
COPO's Avatar
COPO
pic would help out a lot more
Old Sep 11, 2009 | 04:13 AM
rodj's Avatar
rodj
That is the front of the frame. Not a replacement item
Old Sep 11, 2009 | 02:32 PM
redrose's Avatar
redrose
it's welded on but is replaceable...GM p/n 14090676... gr 7.010... MEMBER, Frt Cr Bar Tie...was under $30 back/day (probly 2x if still available), may be 'discontinued' by now, check your local dealer...peabay vette parts shops sell 'em now for abt $100 WITH the front frame 'horns', simple to cut the frame horns off/grind smooth.
try to get it on level before you weld, the factory DID NOT on most.
Old Sep 11, 2009 | 05:22 PM
jeffp1167's Avatar
jeffp1167
you can bend it with ease to get it semi-straight it's not very strong metal.
Old Sep 11, 2009 | 09:40 PM
vettecrazy88
Thanks all. THis help a lot
Old Sep 13, 2009 | 03:25 PM
jeffp1167's Avatar
jeffp1167
the left corner of mine was bent in kinda bad & then the center was pushed in towards the air cleaner. I just used a come along and tied it to a trucks bumper and straightened mine.
the bar is actually spot welded to the frame rails but I would think getting a new one aligned perfectly would be a hassle so I would say just try straightening it the best you can and then use shims to get the bumper right.
Old Sep 13, 2009 | 03:31 PM
jeffp1167's Avatar
jeffp1167
heres how mine was after banging on it and pulling it and even like this my bumper lines up fine now. My car had main skid bar damage & inner impact bumper damage and thats what caused most of the alignment issues not this front bar.
To Bumper mount frame damaged
