SB 2.2Heads
Old Sep 11, 2009 | 12:04 AM
pipe's Avatar
pipe
Default SB 2.2Heads
Will these heads bolt to a 88 89 Vette block. Or is a aftermarket block needed? THANKS Pipe
Old Sep 11, 2009 | 12:33 AM
Mojave's Avatar
Mojave
Yes, they will, but you must make sure the valves won't hit the block. SB2.2 are usually on very large bore engines, and with only a 4.0" bore, they might not clear (might require 4.16" or larger depending on the specifics) . Also, the intake and exhaust are at different angles from a stock 23 degree head.
