idling problem
Old Sep 11, 2009 | 02:49 PM
ndanl's Avatar
ndanl
Default idling problem
hi,
my '91 engine dies in idle, I have ~45 psi on the fuel ramp, put new injectors, new spark wires, new fuel pump+filters and check the injectors with light, all seems to be ok, any hints ? may be a problem with the idle senesor or any sensors ?
thanks,
Dan
Old Sep 11, 2009 | 02:56 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Does it run OK otherwise? Probbably an idle air valve. But check for vacuum leaks and do a search of setting basic idle speed.
Old Sep 11, 2009 | 02:58 PM
ndanl's Avatar
ndanl
sometimes it runs perfectly in idle, and yes otherwise runs great, as much as I can say
Old Sep 11, 2009 | 04:47 PM
94z07fx3's Avatar
94z07fx3
Vacuum leak or EGR stuck open?
Old Sep 11, 2009 | 04:56 PM
WW7's Avatar
WW7
Sounds like the IAC is gummed up. Take it out and clean it and the channels that feed it. Carb cleaner works, and you will also need new gaskets. Check for vacuam leaks first...WW
Old Sep 12, 2009 | 07:51 AM
ndanl's Avatar
ndanl
new gaskets for what ? what do I need to dismount to get the IAC out ?
Old Sep 12, 2009 | 09:41 AM
ndanl's Avatar
ndanl
I dont think EGR have something to do with idling, or ?
Old Sep 12, 2009 | 11:03 AM
94z07fx3's Avatar
94z07fx3
As others mentioned, the IAC should be your first check. I was tossing vacuum and EGR valve into the mix because they too can cause an engine, even a strong V8, to die at idle. If an EGR valve is sticking in the open position due to carbon build up, for example, then it will act like a big vacuum leak and the engine will die.
To idling problem
