1992 starter clicking
Old Sep 11, 2009 | 08:10 PM
williamjrgn's Avatar
williamjrgn
7th Gear
Default 1992 starter clicking
My starter started to click every now and then, and is starting to get worse as time goes, to the point it clicks like 10 times before engaging.
- I was curious how much of a job is it to swap starters and where is it , I guess I could jack it up and find out , but thought it was just as easy to ask!!
Old Sep 11, 2009 | 08:26 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Unless you have a ZR1, its in the same place as every other SBC. Its a pretty easy job
Old Sep 11, 2009 | 10:01 PM
LBYRNES's Avatar
LBYRNES
Lower right, just above the exhaust. You will have to loosen the exhaust system to get the starter out. Only two bolts on the starter.
Old Sep 11, 2009 | 11:00 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
I would remove the starter and replace the parts I specify in this thread:
http://www.corvetteactioncenter.com/...o-starter.html
SAVE the WAVE!
Old Sep 11, 2009 | 11:14 PM
jfb's Avatar
jfb
There are two large copper contacts that get forced together at the end of the starter solenoid stroke that switch 12v to the starter motor. These contacts get blackened and pitted and eventually won't make a low enough resistance connection to pass the 100+ amps the starter motor requires. Continued striking with the solenoid will make a good enough connection to operate the starter motor. You can replace these contacts and save yourself a lot of money for a replacement starter.
Old Sep 11, 2009 | 11:44 PM
whalepirot's Avatar
whalepirot
Quite a load for a guy who doesn't know where the starter is but.......
one of my early fixes was to simply turn these 180* in my Mom's Pontiac starter; fixing the problem.
Old Sep 12, 2009 | 02:57 PM
jfb's Avatar
jfb
Boy you are cheap aren't you! Good thinking.
Old Sep 13, 2009 | 12:56 AM
whalepirot's Avatar
whalepirot
Thrifty, not cheap.
The car had 100k+, so why spend my meager high schoolish bucks on parts?
To 1992 starter clicking
