We have a 94, new to us. I was going to do the TB bypass. My one son works for the local Chevy dealer and told the local tech that his dad was going to do a TB bypass. He said, tell him ;not to do it, your car could freeze up and it will run terrible. It is their for a reason and you wont see any difference. All technical crap to him. Need your guys advice. :confused: :confused:
Touch the throttle body on your car when the engine is hot. Then touch the throttle body on a hot engine that has the TB bypass, and you will understand why the mod is worth doing.
In California you have nothing to worry about. How often does it freeze in Stockton, not too often. The basic idea is that you may reduce the temp of the air going through the throttle body and possibly increase performance because of the cooler air. I have done it and can't say I have noticed and improvement other than being able to touch the throttle body without burning my hands. I think the benefit will outway the possible risk of freezing the throttle body.
You can do it on an L-98. Just tie the two water hoses going in and out of the throttle body together, or find a hose that will bypass it. I did my '89 TA, using a hose from Autozone. Seemed to help idle quality on a hot day. You can also get some rubber caps at Autozone for the two ports left open on the throttle body. Doesn't really matter, but it looks much better :cheers: :cool: :flag
The coolant through the TB is kindof like carb heat in an airplane. Unless it's really humid where you live and you think that the air entering the TB is going to be traveling SO fast as to condense and freeze the moisture from the air and ice your TB butterflys, then you'll probably be alright :D
works on both an L98 and LT1, most GM mechanics (or that type) will tell you not to do it, but ive never heard of anybody having their motor freeze on them
It won't freeze up. The radiant heat from the engine will keep the TB warm w/o running coolant through there. I've been running my 87 in some cool 20* air and when I pop the hood and feel the TB it's nice and warm. I bought a plastic hose connector, 2 clamps and 2 end caps for just over $2.00 from the local auto parts store.
The freezing (intake icing) takes place most easily in temperature ranges of 50 to 60 degress F. when humidity is just right. Has nothing to do with freezing ambient temperatures. The acceleration of the intake flow causes the intake drop in temperature (sorta). Airplanes experience this very seldom. But....when it happens, it will shut you down until you pull over on the side of the road and wait until the engine compartment heat melts the frozen throttle body. The possibility exists. If it didn't, the engineering group would have bypassed the bypass option. :) Your call.
I thought it was more likely to happen around 40 degrees, but I am not expert this subject. It has a better chance to happen in humid FL than in the snow belt. It is rare a occurance anyways.
If you drive in heavy fog in freezing weather you could ice the butterfly's. Or a trip up the mountains in freezing cloudy weather could do it too. Your call, I say slim possibility, but both situations could apply to you.
The icing should only occur when the engine is cold. The heat transfer of a warm engine should melt it.
