ADS Superchip question
Old Feb 20, 2002 | 10:26 PM
VetteNoob's Avatar
VetteNoob
Default ADS Superchip question
Will the chip from an 88 auto work on an 86 auto?
Thanks!
Old Feb 21, 2002 | 01:15 PM
HighHopes85's Avatar
HighHopes85
Default Re: ADS Superchip question (VetteNoob)
86 with iron or cast heads?
Old Feb 21, 2002 | 06:06 PM
VetteNoob's Avatar
VetteNoob
Default Re: ADS Superchip question (HighHopes85)
Sorry. steel, not alum.
[Modified by VetteNoob, 4:06 PM 2/21/2002]
Old Feb 21, 2002 | 06:48 PM
HighHopes85
He heh. My bad. I meant iron or aluminum, but I was typing faster than by brain thinks...which is sad because I type slowly.
The spark curve is going to be pretty different, or at least should be different.
Old Feb 21, 2002 | 07:03 PM
VetteNoob's Avatar
VetteNoob
So does this mean it will not work in my 86?
Old Mar 26, 2002 | 02:23 PM
85WHITEZ51's Avatar
85WHITEZ51
I have an ADS chip (actually 2) for 85 auto's if you would like to try one of them. I will give one to you cheap if you would like. One is the thermo type which requires the 160 degree stat and the other doesn't require the lower thermostat. Don't know if they will work with an 86 but I think it should as we have the same engine and tranny.
Old Mar 27, 2002 | 01:45 AM
VetteNoob's Avatar
VetteNoob
Default Re: ADS Superchip question (85WHITEZ51)
Cool. Id be more than happy to try it since I have to get near the ECM to find the stupid horn relay. If it works, we can work something out. The ADS chip I got from Caseyc I ended up giving to a friend with an auto 88 vert. Thanks Caseyc for the chip.
Old Mar 27, 2002 | 11:08 PM
85WHITEZ51's Avatar
85WHITEZ51
I have it at my appartment as we speek so let me know when you are starting you search for the relay. I will bring it to you or meet you somewhere. I think I could be of some help finding that relay to if interested. If I remember correctly its a cream colored relay up next to the ecm.
Old Mar 27, 2002 | 11:16 PM
VetteNoob's Avatar
VetteNoob
I dont work friday so I may be outside taking apart my dash. I'll give you a call if I decide to yank the puppy apart. Id like to reinstall a 160 in mine for the upcoming summer.
Old Mar 28, 2002 | 10:25 AM
dgoodhue's Avatar
dgoodhue
85 Chips don't work with 86 ECM's
Old Mar 30, 2002 | 09:58 PM
VetteNoob's Avatar
VetteNoob
Default Re: ADS Superchip question (dgoodhue)
crud. thanks.
To ADS Superchip question
