Transmission Didnt Shift
Old Feb 20, 2002 | 10:33 PM
VetteNoob's Avatar
VetteNoob
Default Transmission Didnt Shift
I decided to get on it last night on a back road to see what the car would do and I noticed that I never shifted. I got 100-200 rpms into redline and decided I didnt want to chance it. What could be causing this to happen? Any ideas would be appreciated. (700r4 auto) Oh, it shifts fine during normal driving.
Thanks,
[Modified by VetteNoob, 8:33 PM 2/20/2002]
[Modified by VetteNoob, 8:48 PM 2/20/2002]
Old Feb 20, 2002 | 11:23 PM
VetteNoob's Avatar
VetteNoob
Default Re: Transmission Didnt Shift (VetteNoob)
Anyone?
Old Feb 20, 2002 | 11:42 PM
jay17's Avatar
jay17
When I first got my vette it would shift out of first during wot. It would go up to about 5k and act like it was hitting the rev limiter. During anything other than wot it would shift fine. Turned out to be a bad coil. Replaced it and it's ran great ever since (I do have a different trans). BTW my tach runs right up to 6k before it shifts during wot. Good luck.
Old Feb 21, 2002 | 03:15 AM
tan85vet's Avatar
tan85vet
I have the same problem with WOT shifts...it shifts too late when the motor isnt making power anymore. I think its the governor that causes this, or the weights and springs inside the governor. Change that and it should shift just right.
Old Feb 21, 2002 | 03:33 AM
VetteNoob's Avatar
VetteNoob
Default Re: Transmission Didnt Shift (tan85vet)
Would something like a B&M shift kit do the trick?
Old Feb 21, 2002 | 02:10 PM
Bluevette85's Avatar
Bluevette85
Try adjusting the TV cable, see tech tips.
Old Feb 21, 2002 | 02:47 PM
RadPolo96's Avatar
RadPolo96
Thats happened to me a couple of times, but its justa fluke.
Old Feb 21, 2002 | 02:56 PM
BlueDemon's Avatar
BlueDemon
Default Re: Transmission Didnt Shift (RadPolo96)
The problem is it is an automatic transmission :) . A manual will shift when you make it. In all seriousness, there could be lots of things causing this and I wouldn't want to make a guess and you do the wrong thing.
Old Feb 21, 2002 | 06:44 PM
bogus's Avatar
bogus
Default Re: Transmission Didnt Shift (BlueDemon)
wow, noob... that makes you shiftless... :jester
I agree... but this suggestion makes sence... whenever there is a problem with an auto, I check fluid. make sure it is clean, and that there is enough of it.
[Modified by bogus, 5:45 PM 2/21/2002]
To Transmission Didnt Shift
