Help with Electrical Gremlin
Old Sep 19, 2009 | 08:14 PM
ram0672's Avatar
ram0672
Default Help with Electrical Gremlin
Recently my 94 started having a couple of weird electrical problems. When I open the door none of the interior lights go on. Also, when I shut off the ignition and remove the key the radio used to play until I opened the door then it would go off. Now the radio continues to play. Get out of the car, shut the door and the radio plays. Checked all the fuses and they all appear good. This started happening right after my trip to Carlisle. Drove through a lot of rain that weekend but still had a great time.
Anyone got any suggestions?
Old Sep 20, 2009 | 12:03 AM
jfb's Avatar
jfb
Defective door switch.
Old Sep 20, 2009 | 09:00 AM
ram0672's Avatar
ram0672
Would the door switch also affect the hatch release located on the door?
It no longer works either.
Old Sep 20, 2009 | 10:53 AM
jfb's Avatar
jfb
The hatch switches are grounded by the courtesy light delay timer. If the courtesy lights don't work, then the hatch release will also not work.
Old Sep 21, 2009 | 12:18 PM
trapshooter6's Avatar
trapshooter6
4th Gear
Default Same problem
My 96 started doing the same thing. Thanks for the info.
Old Sep 21, 2009 | 12:49 PM
vette079's Avatar
vette079
Take a small knife or flatblade screwdriver and pry out the little buttonlike pin in the switch.
A few millimeters will do, it´s an adjustment pin in the switch.
Then check if it works like it should with the interior lights.
If not, then the switch is shot.
And unrepairable, 18.99 at ecklers or midamerica.
Old Sep 21, 2009 | 04:09 PM
joe3906's Avatar
joe3906
To Help with Electrical Gremlin
