1.6 rocker arms
I read all the manuals and am mechanically inclined and have most of the engine coming apart (intake, TB, valve covers) but I feel intimidated about doing the roller rockers replacement when they start talking about last, etc...
Is it fairly simple to do and should I be intimidated?
special tools needed?
Best advice is to choose the method you want to use - since there are several different ways to make the swap and adjust the preload - and follow the directions EXACTLY. Find someone who REALLY knows how to adjust the lifter preload and follow his directions to the letter.
As soon as you let the conflicting views of others begin to effect what you're doing, your troubles will begin. Don't mix one method with another.
Best part is that after adjusting them a time or two, you'll come to realize how easy it REALLY is. It's the initial learning curve that can be so frustrating.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!
Will full roller rockers clear the stock black valve covers found on the 93-96 lt1? and with 1.6 self alighn rockers, do the stock lt1 valve springs have to be changed? And anyone know an eazy trick to changing vlave springs with the heads still on the car?
Ive got a fresh lt1 and want to install roller rockers but don't want to pull the heads.
thanks
You'll also need compressed air to hold the valve up to keep it from falling into the cylinder when you replace the springs. Some have used 3/8 rope crammed through the spark plug hole to hold it. Then rotate the engine to compress the rope up against the valve. I chose to use the air instead. You'll need a compression gage kit to get the air on the cylinder. A decent set of wrenches and sockets and a torque wrench are a must! Zip Locks labeled for nuts/bolts and small parts work great. And of coarse a FSM for your year car is always needed! Some pictures for reference taken before you start isn't a bad idea.
If you want some reputable info to read with a lot of great links go here. http://forum.grumpysperformance.com/viewforum.php?f=31 You may have to register to use his forum.
Do your research on this before starting. Like Jake said find someone that has done it before and has some detail of the process and take it one step at the time. It can be a little intimidating but take your time and you'll be fine.
http://www.loperspeed.com/khxc/index.php?app=ccp0&ns=prodshow&ref=1677
https://www.patriot-performance.com/xcart/product.php?productid=159&cat=52&page=2
Or
http://www.jegs.com/i/GM+Performance...95494/10002/-1#
https://www.patriot-performance.com/xcart/product.php?productid=160&cat=52&page=2
http://www.summitracing.com/parts/TFS-30400623-8/
http://www.summitracing.com/parts/ARP-134-7103/
http://www.summitracing.com/search/Part-Type/Valve-Cover-Gaskets/Year/1995/Make/CHEVROLET/Engine-Size/5-7L-350/Engine-Family/Chevy-small-block-Gen-II-LT-based-engines/?keyword=valve%20cover%20gasket
http://www.summitracing.com/parts/TFS-21407200/
OR (Must be measured)
http://www.summitracing.com/parts/TFS-21407150/
http://www.summitracing.com/parts/TFS-9000/
http://www.summitracing.com/parts/MOR-62370/
I can't answer the question on the stock rockers I used 1.6.
You will have to cut the VC's though if you upgrade to 1.6 rockers. I did anyway. Yes, stock locks and retainers will work with the lT4 springs.
