86 Vacuum leak?
Old Sep 22, 2009 | 02:44 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default 86 Vacuum leak?
I broke the end off of this vacuum system part which is located on the driver's side between the distributor and the windshield wiper motor up against the firewall. I am not sure what the part is called or what it does. Also it looks like there are three vacuum hose connections, but there were only two hoses connected.
Can anyone identify this part, know where I can get a new one and what the proper hose connections might be? Any help will be much appreciated. (click to enlarge photos)
Old Sep 22, 2009 | 03:42 AM
nutz4c4's Avatar
nutz4c4
Looks like the check valve for the cruise control and possibly the A/C if I remember correctly. I think I got one from Corvette Cental a few years ago.
I can get some pics later today if no one else comes up with any.
Old Sep 22, 2009 | 03:51 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Thanks. Any photos will be a great help. I don't have cruise control so it might be A/C.
Old Sep 22, 2009 | 06:31 AM
toptechx6's Avatar
toptechx6
GM part number should be 14056648 available from a dealer for less than $10 or forum vendors such as GM Parts Direct or GM Parts House, also from most parts stores, it is a one way vacuum check valve.
http://www.gmpartsdirect.com/results.cfm
The vacuum hoses just slide on, but make sure you remove the old nipples if they broke off in the hose.
Old Sep 22, 2009 | 07:30 AM
runner140*'s Avatar
runner140*
Its a check valve and can be purchased at any auto parts store for under $5.00. and looks like this new:
Old Sep 22, 2009 | 08:24 AM
floridamale's Avatar
floridamale
Old Sep 22, 2009 | 12:36 PM
pmihaltian's Avatar
pmihaltian
Slingshot
You guys are GREAT ! Thank you.
Old Sep 22, 2009 | 03:54 PM
nutz4c4's Avatar
nutz4c4
Default Pics as promised
At drivers side
Takes vaccum at the rear of the plenum
Hope these make sense
Old Sep 22, 2009 | 05:33 PM
pmihaltian's Avatar
pmihaltian
Slingshot
At drivers side
Yes, that's helpful. Looks like the large end goes to the big vacuum hose under the plenum and the small hose coming over the valve cover goes to small connector T coming off the small end. Does this sound right to you?
Old Sep 22, 2009 | 07:22 PM
floridamale
Just be careful to not break or loose the small plastic line running into the bottom if it breaks off inside the wire loom along the firewall its a real PITA to get to
To 86 Vacuum leak?
