Starting Problem. HELPPPPPPP
Old Sep 22, 2009 | 11:01 PM
aklim's Avatar
aklim
Default Starting Problem. HELPPPPPPP
Car was running ok. It would die in idle once in a while. Yesterday, it wouldn't crank. Everything seemed ok. Security light did not come on. Crank it but it wouldn't crank. Smoke seemed to come out of the radio area. Starter relay was replaced but that was not the answer. Nothing seemed wrong with the Neutral Safety Switch.
From the location, only one thing remains. The CCM. Is there a way to test it before I have to replace it?
Old Sep 22, 2009 | 11:48 PM
jfb's Avatar
jfb
Boy would that be neat if you told us what year Corvette it is.
The CCM isn't involved with the starter motor circuit. You have a VATS problem. Use the search function, there is a ton of info on VATS. I have typed the test procedure more than 380 times.
Old Sep 23, 2009 | 05:20 AM
toptechx6's Avatar
toptechx6
At least the OP does have his profile filled out and on his 91 the CCM is very much a part of the starter motor circuit.
It is possible to pull codes from the CCM, but I am not sure it will identify the problem if it went up in smoke. See this link, then scroll down to Sequenced Code Recovery 1990-1993. As always retrieving codes is just a starting point for diagnosis, you will need the correct FSM to isolate the problem,
http://www.corvettephotographs.com/c4vettes/codes.htm
I have been told forum vendor vette2vette can get CCM's rebuilt but have not tried it myself, good luck.
Old Sep 23, 2009 | 08:13 AM
aklim's Avatar
aklim
Sorry. it is a 91
Old Sep 23, 2009 | 09:02 AM
aklim's Avatar
aklim
Did the paperclip trick and got module 1 C12 and module 4 ---
Old Sep 23, 2009 | 10:46 AM
toptechx6's Avatar
toptechx6
The --- indicates there are no codes in the CCM (module 4)
Verify you have a fully charged battery and cable connections are clean and tight at the battery and starter terminals. The starter and charging system diagnosis section of FSM book two says to follow the procedure in chart #1 if no codes are present in the CCM.
Old Sep 23, 2009 | 11:47 AM
aklim's Avatar
aklim
Battery is fully charged and I took off the cables and re-attached them.
Still I wonder why there was smoke from the radio when I started to crank it. I will have to take out the CCM and see if it smells bad.
Old Sep 23, 2009 | 09:58 PM
aklim's Avatar
aklim
OK. I have used the FSM and cannot find a single code and yet it doesn't start. Battery charged and still, no joy.
If it isn't the CCM, why the smoke from the radio area?
Old Sep 23, 2009 | 10:52 PM
aklim's Avatar
aklim
Well, after trying to remove the CCM, I gave up and called Gordon Killbrew. He gave me the weirdest idea. Follow the yellow wire from the Neutral Safety Switch. WTF!!! NFW in hell. Oh well, I'll go take a look. Sure enough the yellow wire was burnt and smoked with me twitching the key. Guess I will have to reinstall the CCM brackets and put it back together after I fix it. Best $20 I spent in a long time.
Old Sep 24, 2009 | 01:45 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Your a lucky man.
When I called about a suspension problem,
I was charged 45 bucks and told, "AHhhhh, I dunno"
Complete waste of my time and money.
The man is sharp, no doubt about it.
But not perfect.
Old Sep 24, 2009 | 07:01 AM
86PACER's Avatar
86PACER
Originally Posted by JrRifleCoach
Your a lucky man.
But not perfect.
Trying to fix people's cars sight unseen over the phone has to have it's limitations.
Old Sep 24, 2009 | 07:56 PM
aboatguy's Avatar
aboatguy
Your a lucky man.
But not perfect.
Next time your stumped and willing to pay for the wrong answer, call me I'll give you one ambiguous answer for 25 bucks or two for 45 dollars.
Mike
Old Sep 24, 2009 | 11:45 PM
JrRifleCoach
At least I got the laugh for free! LOL
Old Sep 26, 2009 | 04:33 PM
aklim's Avatar
aklim
The automotive gods have smiled on me. Car starts.
The wire was burnt in who knows how many places. I used a 10 ga wire and ran it from the relay.
4 wires on the relay. The last GD MF SOB who fixed it must use all 12 ga yellow wires. WTF!!!
Old Sep 26, 2009 | 04:39 PM
86PACER's Avatar
86PACER
Nice.
Old Sep 26, 2009 | 04:41 PM
aklim's Avatar
aklim
Originally Posted by 86PACER
Nice.
CCM was good. That was a MAJOR relief since you can't get a CCM except to give them yours for a rebuild. Relay was fine after all. Only the wire was FUBAR. Actually, FUBAR doesn't begin to describe it even
Old Sep 26, 2009 | 04:46 PM
aklim's Avatar
aklim
So what was it?
Burnt yellow wire. In several places too.
To Starting Problem. HELPPPPPPP
Old Sep 26, 2009 | 05:00 PM
desertmike1's Avatar
desertmike1
"The last GD MF SOB who fixed it" is this a common problem with these cars, and what years are effected?
Old Sep 26, 2009 | 11:58 PM
aklim's Avatar
aklim
Pretty much every year can be affected either when owned by or fixed by some numb nuts. I mean, can't you use some common sense and NOT fix it with 3 out of 4 wires made from the same spool?
Old Sep 27, 2009 | 12:23 AM
jfb's Avatar
jfb
He knew where the wires were going, what is your problem?
