RHD Bleed order?
Old Sep 28, 2009 | 11:02 PM
dailo's Avatar
dailo
Default RHD Bleed order?
Anyone with a RHD know if the GM method of furthest away from MC first - RR, LR, LF, RF, for a 91 vette still applies to our cars? (since the MC is on the right side now)
i cant seem to have the bleed done right.
Cheers
Old Sep 29, 2009 | 10:15 PM
batchman's Avatar
batchman
Per 91 FSM, and my experience is it matters, bleed order is RF, RR, LR, LF. If you think about it, that's the order by distance from the ABS unit. If your ABS unit moved from behind the left seat to behind the right seat, I'd reverse this order.
Good luck,
- Jeff
Old Sep 29, 2009 | 10:34 PM
rodj's Avatar
rodj
Never seen the ABS relocated in a RHD conversion so nothing changes for bleeding.
The MC on the right just means the MC to ABS lines are longer ; that's all.
To RHD Bleed order?
