Code 42 poping and misfire
Old Sep 30, 2009 | 05:55 PM
Cal942's Avatar
Cal942
Default Code 42 poping and misfire
I have a 1987 vette it has been switched to the Speed Density 7730 ecm. It has small base distributor out of 90 model with remote coil. Msd box 6421 6a al 2 and msd Blaster ss coil. I am getting code 42 the engine is poping out the thottle body and misfiring out the exhaust like the timing is not adjusting. what would you check first grounds module pickup or wire going to ecm? any help would be apreciated.
Old Oct 1, 2009 | 01:29 PM
josephf31's Avatar
josephf31
Default Code 42
is for ECM so I'd check that first.
Old Oct 1, 2009 | 03:10 PM
pr0zac's Avatar
pr0zac
test your ignition module.
Old Oct 2, 2009 | 01:06 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
check for a cracked dist. cap
To Code 42 poping and misfire
