intake on 86
Old Oct 1, 2009 | 09:17 PM
leadshred's Avatar
leadshred
Default intake on 86
im stroking my l98 this winter. where can i find a good intake for it? choices seem limited , ive looked at summit, and corvette america, but nothing really.
Old Oct 1, 2009 | 09:45 PM
l98tpi's Avatar
l98tpi
Max G’s
IMO I don't know why anyone would go to a carb setup when a carb is not as efficient as injectors. What you should ? is what you intend to do with the car? Is it a cruiser, autox,drag strip, or track car. The TPI intake is restrictive, but only past 5,500 rpm. The benefit of the TPI intake is the toque boost it provides. A different set up available is the mini ram which shortens the runner length and makes it possible to keep making power past 6,000 rpm. Do your research before spending a lot of useless dollars on building up your engine. You'd be surprised how much power you can extract from that L98 without spending thousands of dollars.
Old Oct 1, 2009 | 09:48 PM
l98tpi's Avatar
l98tpi
Max G’s
I was answering your original ? Check out TPIS, Lingenfelder(maybe).
Old Oct 1, 2009 | 09:58 PM
383tpimachine's Avatar
383tpimachine
HSR (need modification)
Miniram
Superram
LT1 converted
FIRST
and then the bolt on pieces for the stock
I went with a USM HSR. its $$$$ tho
Old Oct 2, 2009 | 12:39 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I have a superram on mine, but they are a little hard to find. You'll need to do something because a 383 will stop making power at around 4000 rpm with a stock intake.
Old Oct 2, 2009 | 01:00 PM
vader86's Avatar
vader86
Depends on what you want out of the car, see my website (click name) and think about a plan before you spend money.
To intake on 86
