383 advice
Old Oct 4, 2009 | 03:33 AM
marinecpl's Avatar
marinecpl
4th Gear
Default 383 advice
1987 with a 383, 280H magnum comp cam, rpm performer and 600CFM Holley carb, should this run ok with the stock torque converter? well it really wont run at all until i find a ribbed water pump pulley and starter, also dropped the engine in today.... man engine was to high have to find a cowl scoop or hood.
Old Oct 4, 2009 | 03:42 AM
rodj's Avatar
rodj
Originally Posted by marinecpl
engine was too high have to find a cowl scoop or hood.
Most use a drop base air cleaner for clearance
Old Oct 4, 2009 | 02:30 PM
383vett's Avatar
383vett
The 280H cam is a pretty stout cam. Might want to idle higher than the stock converter will be happy with. Only one way to find out. Run it and see. Some manifolds are higher than others and could present a clearance problem. When I had my car carbed, I was able to find a lower profile Weiand maniflold.
Old Oct 4, 2009 | 03:55 PM
pr0zac's Avatar
pr0zac
i dont think the stock conveter will like it.. i had a similar yet roller cam in a carbed camaro with a stock stall and you could feel it pull on the lope. not saying it won't work but for traffic its not going to be ideal
Old Oct 4, 2009 | 04:42 PM
marinecpl's Avatar
marinecpl
4th Gear
I would but i have 1/8" clearance above the carb so can't even put a air cleaner on for now but a good idea may have to go with a special hood
Old Oct 4, 2009 | 04:47 PM
marinecpl's Avatar
marinecpl
4th Gear
Can't wait to see what this thing does man if i get pulled over here in san diego i'm screwed though, ya without a bigger hood i don't think the carb will be able to breath. So this is my first forum awesome help thanks guys, anyone know where i can find a 5 groove water pump pulley $100 seems crazy for a pulley
To 383 advice
