86 centerbolt heads
Old Oct 4, 2009 | 09:29 PM
Bensons86's Avatar
Bensons86
Default 86 centerbolt heads
I am trying to find a good set of heads with a chamber size of around 58cc like stock with intake runner volume around 180cc. I have the centerbolt aluminum heads (128's) for the 1986 models. Summit is telling me that they only have one head that will even bolt up to mine. Here is their quoted statement.
Summit:
"These are the L98 heads with center bolt valve covers, but the earlier angle intake bolts. This configuration was used only on the 1986-1991 Corvette. The only direct replacement head available is through Edelbrock."
http://www.summitracing.com/parts/EDL-60879/
These heads have only a 165cc runner volume. He further went on in the next email to tell me that I was placing too much emphasis on the runner length and basically inferred that the 60879's were just fine. Is this guy smoking crack, or are there other good options out there with a little better flow? I was looking at the TFS's with the 175cc runner volume, but again...he said that they didnt' have anything that would bolt up to my 86'.
Old Oct 4, 2009 | 09:41 PM
JackDidley's Avatar
JackDidley
Yes hes smoking crack. You can use almost any small block head except LT1s. Most can be milled to get the 58 cc chamber. There are also different angles on the spark plugs but thats not usually a problem.
Old Oct 4, 2009 | 09:59 PM
rodj's Avatar
rodj
The distinction in their eyes is in " bolt up " as in direct replacement using all OEM parts.
As stated you can use any SBC head but you might have to change to reg perimeter bolt covers
Old Oct 4, 2009 | 11:35 PM
Bensons86's Avatar
Bensons86
Alright. Sorry. The guy kinda freaked me out. I had visions of me purchasing the wrong stuff and then getting screwed or at least hassled in the whole return process. So, the heads will otherwise bolt up fine, the only difference being that the valve covers will have to be changed to accommodate the perimeter bolting style, versus the centerbolt? That being the case, that should bring us full circle to these.
http://www.trickflow.com/partdetail....3&autoview=sku
Other than the fact that I will have to purchase new valve covers, does anyone see a problem here for my application?
Old Oct 4, 2009 | 11:43 PM
rodj's Avatar
rodj
You are paying $250 for .600 lift valve springs
Buy these and put the springs of your choice on for cheaper, then sell the TFS springs
http://www.summitracing.com/parts/TFS-30300001/
Depending on your cam you could run ZZ4/LT4 springs ; good to .525 lift.Under $40 a set from the dealer.
The $$$ difference will pay for your new shiny rocker covers
Old Oct 5, 2009 | 09:25 AM
JackDidley's Avatar
JackDidley
I like them and they will do the job. Rod has a good point about the springs, but I would use them as is. Gives you room to grow in the camarea. Have to figure in the labor to set up and install a different spring also.
Old Oct 5, 2009 | 10:32 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
The problem would be if you had iron heads, and used 58cc heads to replace the iron originals. They are 64cc if iron.
(The iron headed engines did not get the dished pistons.)
Old Oct 5, 2009 | 10:11 PM
Bensons86's Avatar
Bensons86
what rodj is saying might be a really good idea actually, since I have already purchased the lt4 springs, clips, etc, to revitalize my old heads. The machine shop is pretty cheap on that stuff, so I would definitely be saving money. Hmmmm.
the TFS-30300001 have d-port exhaust where my originals have square exhaust ports. Does this make a difference? The ones I originally linked to had the square exhaust like the factory ones.
Old Oct 5, 2009 | 11:06 PM
rodj's Avatar
rodj
The 113's alum heads have D ports and used the same exh manifold as the earlier heads
Old Oct 6, 2009 | 10:32 PM
Bensons86's Avatar
Bensons86
The only other difference I see between the 01's and the 03's is that the 03's have dual springs per valve and the 01's have single springs per valve. Anyone know exactly what that means to me?
Old Oct 7, 2009 | 12:47 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Plus, the D-ports would be better if you go with headers (like you mentioned to me).
Dual springs provide add'l valve control for higher lift and/or more aggressive cam profiles. If you're going to use a hotcam, then you don't need dual springs. Buying the base head and swapping your LT4 springs in -- would be the most cost effective solution.
Old Oct 7, 2009 | 02:36 AM
rodj's Avatar
rodj
That is what you are paying the $250 extra for;
the optional springs rated for a lift you will probably never see.
Old Oct 7, 2009 | 04:46 PM
Bensons86's Avatar
Bensons86
Thanks guys for all chiming in. I really appreciate you all holding my hand on this deal. I don't know about for you, but spending that kind of money on heads is a lot for me, so I wanted to be sure that I was getting what I needed. looks like I will go with the 01's and then swap in my lt4 springs. I was wondering what I was going to do with those. Seems like a good cost effective solution.
What would the other springs be worth on CF?
BTW when all of this is done and said, I will post pics on the progress. I know how you guys like pics.
Old Oct 7, 2009 | 07:29 PM
rodj's Avatar
rodj
Are only worth $40 new and everyone here knows about the ZZ4/LT4 ones @$40
Would put them up on 3rd Gen for someone looking for a 305 upgrade
To 86 centerbolt heads
