loose tilt wheel
Old Oct 5, 2009 | 12:56 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default loose tilt wheel
my tilt wheel is a little loose in some positions and more so in others, is there a way to fix this? thanks
Old Oct 5, 2009 | 02:14 PM
SmokinRide's Avatar
SmokinRide
bummer, mine is loose too...
Old Oct 5, 2009 | 02:26 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Need to rebuild mine too.
You need to take it apart and replace either the pins or the mechanism.
Old Oct 7, 2009 | 12:50 PM
josephf31's Avatar
josephf31
Default No
replacing the pins won't help. It's the housing where hte pins go in that wears out because it is cheap/soft metal, and GM does not make that part anymore.
Do a search on the subject and you will find many many articles, tips, and links on the subject.
Bottom line is there is no cheap/easy fix.
Old Oct 7, 2009 | 02:55 PM
2012 coupe's Avatar
2012 coupe
Default Tilt wheel fix
Here is the GM part # for the kit from GM to fix the problem:
26002678
I got it from a Buick dealer in Winston-Salem NC.
Old Oct 7, 2009 | 03:03 PM
NASCAR314's Avatar
NASCAR314
26002678
What all comes in the kit, if I may ask? New housing?
Old Oct 7, 2009 | 03:12 PM
secondchance's Avatar
secondchance
http://domesticmisfits.net/forums/viewtopic.php?t=124
This link may help.
Old Oct 7, 2009 | 07:22 PM
2012 coupe's Avatar
2012 coupe
Default pivot kit
it comes with new larger, (OD) pivot pins, new spring, spring cap, new metal bushings.
Old Oct 7, 2009 | 08:21 PM
kimmer's Avatar
kimmer
Originally Posted by secondchance
holy crat think ill bungee it
Old Oct 7, 2009 | 09:11 PM
NASCAR314's Avatar
NASCAR314
It's not that bad if you take your time, and take digital pics during disassembly ( a lot of pics ) and lay everything out neatly as you take it off so it makes re-assembly much easier.
I did the 4 loose screws with loc-tite method on a 1978 Olsmobile tilt colum in my hotrod and had no troubles. But....I did refer to my digital pics several times! things like "clip placement", "which way a spring goes", and so on. The pics on that 92 steering colum link above are very simalar to the 1978 colum I did, they have not changed much, except for the airbag related goodies.
Old Oct 8, 2009 | 01:25 AM
pologreen1's Avatar
pologreen1
JB weld or better yet just spray foam up in there
Old Oct 8, 2009 | 10:21 AM
josephf31's Avatar
josephf31
Default The kit is discontinued
good luck finding a dealer who still has one, pretty much every GM car from that era ate through these housings.
Old Oct 8, 2009 | 10:25 AM
BrianCunningham
26002678
Thanks guys
Old Oct 9, 2009 | 09:15 AM
mnypitVette's Avatar
mnypitVette
That thread is awesome. Gives a great detailed rundown.
Anybody know where to get one of those tilt column pivot pin puller if we dont have access to a tool truck?? I am hopefully getting a buildable column and before I put it in I want to rebuild it.
Old Oct 9, 2009 | 09:20 AM
mnypitVette
26002678
I just checked GMpartsdirect and they dont have this part number listed. Is it still available? how long ago did you get this?
NEVERMIND, just found it on Scoggin Dickey.
Old Oct 9, 2009 | 12:16 PM
josephf31's Avatar
josephf31
Default I
think I found my on eBay or at a Napa store. You don't need a puller for the old/worn columns, the pins will fall right out! LOL
Old Oct 9, 2009 | 12:17 PM
josephf31's Avatar
josephf31
Default Gm
discontinued the part. Who/what is "Scoggin Dickey"? and how much for the kit? thx
To loose tilt wheel
