Broken Window Stop Guide. Again!
Old Oct 6, 2009 | 12:29 PM
rickneworleansla's Avatar
rickneworleansla
Default Broken Window Stop Guide. Again!
I replaced my broken window stop guide Dec 2007. It looks like the new replacement piece has now broken after only a year and a half. I'm going to replace it again but I was wondering why it broke after such a short period of time.? Cheap plastic crap!? The passenger window is still functioning with the original factory piece.
Here's the write-up I did in 2007. This time I'm doing the outer window seals also.
http://forums.corvetteforum.com/c4-t...indow-fix.html
Old May 18, 2010 | 09:27 PM
rickneworleansla
About to order another one. Any ideas here? The new convertible top release cable I just replaced several months ago also just broke. WTF?
Old May 18, 2010 | 09:54 PM
xole's Avatar
xole
I know the newer version from GM no longer has the felt on it like the old ones.
The appear to be similar plastic though. I was afraid it would rattle without the felt but it does not.
Good luck!
-D
Old May 18, 2010 | 11:07 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Just curious, you ride around with the window partially down?
I'm thinking the window has been flopping around causing premature plastic weaking.
Old May 19, 2010 | 12:27 AM
rickneworleansla
hmm.. Not really. I hate the cold, so in the winter the windows are always up. In the summer I usually have the windows all the way down.
I think I'm going to pull off one of the stop guides this week and bring it to home depot to see what else I can come up with to fix it. Same thing with the convertible top release cable. Hopefully I can come up with a stronger solution.
Old May 19, 2010 | 06:17 AM
HlhnEast's Avatar
HlhnEast
Unfortunately aftermarket parts rarely stand up like our OEM stuff. Nor do they fit right, etc etc. Just the nature of the beast.
To Broken Window Stop Guide. Again!
