Power Chip Question
Old Oct 7, 2009 | 10:30 PM
Varden's Avatar
Varden
Default Power Chip Question
I recently bought a 1988 corvette in which the previous owner installed a hypertech thermomaster power chip and 160 degree thermostat. What performance effects might these have? I can't find any good specs anywhere. Any info would be welcome.
Old Oct 7, 2009 | 10:48 PM
JackDidley's Avatar
JackDidley
If you live where it gets cold, it will take a long time to warm up. I used to use one in my 87 with a 180* thermostat. I really did not see much in the way of power gain, but the fuel mileage was better with the chip (and premium gas).
Old Oct 8, 2009 | 12:08 PM
CFI-EFI's Avatar
CFI-EFI
With that cool a stat, your engine wear will be accelerated. What temps does your engine run at? I tried that same combination in my '84, before I knew better, and I documented slower 1/4 mile ETs with the chip. I sent it back. If it were only worthless, it might be tolerable.
RACE ON!!!
Old Oct 9, 2009 | 11:08 PM
Varden's Avatar
Varden
It's not registered yet so I haven't had a chance to drive it to see what temperature it runs at. I'll get back as soon as I know though.
Also, the previous owner was a GM mechanic, so I hope he knew what he was doing.
Old Oct 9, 2009 | 11:49 PM
Muffin's Avatar
Muffin
There's that Hope thinge again. I don't think there is a serious car nut that will say the chip you have is worth it's cost. There are several tuners here that will do better for less.
Old Oct 10, 2009 | 12:29 AM
LT4 F45's Avatar
LT4 F45
i did add a chip + 160 stat + airfoil + k&n at the same time in my previous 87 L98 auto 3.07 diff and didn't see many effects on the ground so this is mostly psychologic like the air foil that suppose to add 12-16 HP in any books but +/-worthless in any dyno testing for few HP combined with all these ... great if you have it for free but i will not pay anymore for these in my 92 that already have the airfoil in when i bought it and i have done the muffler eliminator on this LT1 that if not adding any HP (I DOUBT) give me a smile everytime i on the GO pedal...
Old Oct 10, 2009 | 12:36 AM
Varden's Avatar
Varden
Should I be worrying about any detrimental effects though? I don't have the stock chip- the guy must have gotten rid of it- should i consider getting one? Or does it not matter?
Old Oct 10, 2009 | 12:46 AM
LT4 F45's Avatar
LT4 F45
i don't think there is nothing to be worried about that or any negative effects on the car or engine whatsoever... except if you drive the car in cold area...
Old Oct 10, 2009 | 01:30 AM
Varden's Avatar
Varden
How cold? It gets to 15 degrees minimum during the winter where I live, but I doubt I'll be driving in conditions anywhere close to that. It'll probably just sit in my garage all winter.
Old Oct 10, 2009 | 01:46 AM
LT4 F45's Avatar
LT4 F45
i live in canada so there is no problem... if you don't drive the car in cold wheather but if you get the car started or to run anytime in winter make sure that the coolant and oil temp is getting up to +/-180 zone before you get it back in storage and make sure you get the oil changed as soon as you get it out...
Old Oct 10, 2009 | 02:07 AM
CFI-EFI's Avatar
CFI-EFI
The chip isn't likely to hurt anything but performance. However, that thermostat will, with the prolonged warm ups, reduce fuel mileage and accelerate engine wear, in any weather.
RACE ON!!!
Old Oct 10, 2009 | 10:01 AM
cumbercr's Avatar
cumbercr
RACE ON!!!
I believe the Hypertech chip also modifies set points for the fans. So replacing only the thermostat may not be a good option.
To get information on the correct thermostat, do a search on this forum. I suggest you check Vader86's page. He has a very good writeup on the subject. I've also seen some GM Tech Articles. Note that this is a debatable subject on this forum. Before spending money just realize there are many opinions that are presented as fact. You need to look at your driving conditions before spending money on a new chip.
Old Oct 10, 2009 | 11:42 AM
TA's Avatar
TA
RACE ON!!!
I also documented slower 1/4 mile ETs when I installed a Jet Stage 2 chip (probably similar to the Hypercrap chip) in my car long ago. If I recall it was about .1 to .15 slower in the 1/4 with the Jet chip. I sold the thing on Ebay the next day.
Old Oct 10, 2009 | 12:10 PM
3D-Aircrew's Avatar
3D-Aircrew
Default Exact Stock proms are hard to find
I had a hypertech thermosmaster that went bad in my 86 vert. I couldn't find the stock chip after a month of searching. I imagine the 87 will not be any easier to replace.
I was forced to get a replacement hypertech. Live in florida and my temps stay @ ~190 in the heat.
To Power Chip Question
