C4 LS swap a different perspective
Hey guys I am trying to find a new market for our C4 swap headers. How many of you would be interested in this type of build?
C4 Lsx pro street on the cheap-
This isn't a daily driver, but more so someones hobby car they could have fun with for a reasonable amount of cash;
•Acquire or use your own thrashed C4
•acquire LSx motor- truck or alum block
•Rip the dash and hand fab one with analog gauges (save time trying to interface C4 dash with later ECU)
•Pull out as much useless crap as possible i.e. a/c, heat, and so forth
•MAybe some lightweight body parts i.e. hood, roof, lexan rear window.
•Lowered
•sinister satin black paint job
•loud exhaust
$3000 car
$800 motor and ECU
$500 guages and dash material
$650 coated headers
$2000 adpater plates, power steer, clutch, bellhous, fluids, misc
$400 wiring or paying electrician
$1500 min head work, cam, tune, maybe a little spray into TB
=$8850 (figure 10K for the other nickel and dime crap)
I tried being as realistic as possible, but this should get you a low 12's car for about 8-10K if you shop smart.
Before you guys say just go buy a C5, or dump 4k into an LT, please keep in mind that's not the point and nearly not as much fun.
__________________
Melrose T-Top Int. http://www.melroset-tops.com
Melrose Headers http://www.melroseheaders.com
815-758-2783 Melrose Int.
100 W Ellwalk, Cortland, IL 60112
•Lowered
•loud exhaust
$3000 car
$800 motor and ECU
$650 coated headers
__________________
10k.Does'nt sound good too me.And I don't really get all this talking about putting a LSX motor in a C4 all the time.Why waste all this time doing all this work when the C4 has a perfectly good motor.
1985 Vette (12-26-2019)
It may be worth it for you guys to determine if your headers would work in this scenario. A few known reference points and measurements should give you an idea.
Collections Ban
Location: Name calling begins in the absence of fact and reason
1 Post
I use to think that having a stripped car for the street was bada$$... but after spending 15 years in Arizona, I've changed my mind.
Air-conditioning is COOL (pun intended, lol)... insulation and functioning power equipment is cool...
I've seen enough of my less intelligent friends play off a gutted "hatchback" in the dead middle of summer as being "alright".... the idea of a heat stroke just isn't appealing to me! lol...
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Melrose-
I'm a bit lost with the OP. Are you quoting the price for the do-it-yourselfer OR you guys completing the swap for the customer?
Disclaimer before I go on my rant-
I really like you guys as a vendor. I think you guys make great quality components for the corvette community. I've heard nothing but good news from the guys that have used your products.
However (rant on):
I don't understand why we've got a handful of vendors that make random components for the LS-x swap, kind of a half-a$$ attempt if you as me.
I can only imagine having a c4 sitting in the average shade-tree mechanic's garage with the original guts pulled out of it and the Lsx sitting in the engine bay (not even attached of course) BUT "at least" it's got a nice set of headers on it! lol...
there are (and now have been for several years) a number of vendors that offer COMPLETE ls-x swap kits for none-GM platform cars (miata, rx7, fiero, 240sx, etc.) for the life of me I can't understand why we can't get the same support?
*if* someone (plug vendor name here) would step up and offer a COMPLETE kit, I think these things would be flying off the shelves.
more importantly, offering to merge the two harnesses or sell a harness that would allow for a seemless interface between the c4 and the Ls-x. (if just this item existed, i would be much more inclined to pursue an Ls-x swap).
The guys that do offer some sort of kit typically try to get around the creature comforts (AC, cruise, etc.) Making an already impractical car even more impractical.
However (rant on):
The best way right now to go LS in a C4 is the Motown LS/SBC block. It's a tall block though and I don't know where it would put the heads relative to where an LSX swap would.
Sorry,but what kind of car are we going to be driving around in for
A $10K LSx swapped C4 would be a pretty fast car for a pretty small investment. You might be able to do it with a C5, if you sell off the entire interior.
I'm beginning to wonder if there is no C4 swap kit out because of all the misinformed haters...
F-body oil pans fit. C5 front accessories work. Both are plenty common. You could go the truck LS route, LS1 (non LS6) manifolds are down right cheap. I picked one up for $50 shipped.
I do not want to start an argument, but I really disagree with the "why put an LS1 in a C4 when it has a good motor" stuff. If you honestly think the old small block is superior or even remotely equal to the LS1, much less and LS3... or truck 6.0, L92, or LS7... you are in denial my friend. The LS engines now are to the old SBC as the SBC was to the flathead ford. Time marches on.
You see these engines swapped into everything from 4x4 rock crawlers, to Honda Civics. There is a reason for that! So why not put one in a light, affordable, well designed chassis like the C4?
If you don't like the idea, go post on the best cam for an L98 threads. Why is so much animosity generated at the LS1 C4 idea?
I'd love to see some good swap tech in a thread without all the nay-saying. And I know I'm not alone!
St. Jude Donor '03 & '05
i was going write out a nice long post on how ridiculous i find this.. but i am sure this thread will be locked and forgotten in no time. also with remarks like that from a vendor trying to sell something you aren't doing yourself any favors.
All the LS series blocks are amazing. The aluminum ones are really, really strong, and very light. The iron blocks are cheap, really cheap, as well as really strong. Is the Motown LS/SBC block aluminum? If not, there is no way I would want to run it. Plenty of cheaper aluminum blocks out there.
No, no it doesn't, not compared to an LSx.
#33
sure, you'll get the guy that has tens of thousands of dollars in tools and a lift in his "garage" that can tackle this with all the extra time in the world, but for the "budget minded" (yes some hobbiest's actually have a budget), this option is a non-option....
I want to see more effort placed in making a well researched parts list, with part number etc of what does and doesn't work. Otherwise, you've got hours of research ahead of you to figure out what will and what will-not work (not that that's a bad thing, some people like that sort of stuff). It's just clear that these details have been worked out for non-GM platform cars
To the OP-
I can't shoot the messenger. After all, you've only been approached by a series of shops to supply them with a quality header kit with will work with their idea of doing an Ls-x swap into a c4 and you guys have done an outstanding job (nice lookin' headers). I really DO hope that more people are motivated to do this type of swap, and the existing (or new) vendors step up and offer the needed components to FINISH this type of swap for the average-joe.
****edit****
BTW, when someone says the L98 or LT-x is a "good" engine, the in-depth response is.... "for $10K, I can make a fire breathing monster that will crush a STOCK LS-x swap, why the he11 would I dump $10K into a swap only to have a used engine with near-stock horsepower figures"... this again is the thought-process of the budget-minded hobbiest.
sure *if* I had the money I'd just have some reputable shop shoe-horn a big-inch Ls-x into my c4 and call it a day.
#34
#35
Would I swap an LSx into a C4 if I had the option?
nope.. sorry.
Its really not worth the headaches involved, the comforts removed, and the costs.
Now, I have an LT4, which dyno's identical to an LS1, so if I spend 10k and probably a year or more on the swap, while loosing AC, and fighting with electrical problems. I will gain. 0HP and loose a ton of features.
If I go to a worked L92, I'm spending more money, and gaining about 15HP.
If I go LS2 (which I don't even know if it will fit or not with head clearance) I'm spending a TON.
And don't even talk about GenIV being practical, an LS7 crate motor is 15k by itself. Add roughly 10k getting the monster to fit and run, and I have 25k in, to gain about 225WHP.
Sorry, I'll buy one of the new LT blocks, hog it out, throw on some AFR heads, and a set of Melrose headers and be out the door in about a month with LS7 power, and all my stock goodies.
Not enough? I'll just spray the hell out of it... or call up Greg at Blowerworks, now I'm talking about 800+HP range, and I'm STILL out less money, and with less than 1/4 of the downtime.
On an L98 car. I could see it as being a bit more of an option.. but really, I don't see anything in history that says a good ol SBC can't make amazing power.
My .02 on the deal.
Also, I'm hoping to get my Melrose headers soon, I really do like your products, and your prices are very reasonable, just waiting for the bank account to wake back up
nope.. sorry.
My .02 on the deal.
#36
I do aftermarket EFI and tune real race engines every day. A decent Gen 1 410 will make 775 to 800 hp all day long the same as an LSX so where is the advantage to be had..
#38
#39
nope.. sorry.
My .02 on the deal.
nope.. sorry.
My .02 on the deal.
All LS motors with the exception of aftermarket blocks have the same exterior dimensions, so clearly your LS2 comment is ill informed.
L92s make 403 hp stock! Easily over 500 w just a cam. So where your 15hp gain comment comes from is beyond me.
Now, no one is saying an LT4 is a boat anchor. If I had an LT4 car I would be less likely to swap. Yes, you could build a high powered LTX car. But that doesn't mean it is a bad idea for someone else to go LSX, right?
On the other hand, the crossfire and TPI cars cannot easily or cheaply make the power of a cheaply modded LS1. Not to mention that LS1 is lighter, and in many cases cheaper dollar for HP and more dependable HP for HP.
Yes, C5s are getting cheap. Yes it would be easier to just buy a C5 that already has an LS1. That being the case, why do people buy street rods, or put LS1s in muscle cars when they could just buy a C5 or F-body that came with an LS1. Because they want to. Because the C5 and F-bodies have limiting factors also...
Now I already have a nice LS1 02 Z28. Why am I doing the swap? Because the C4 is an excellent chassis for the track (road course). It will be lighter (especially stripped down). It will be easier to work on (C5s and F-bodies are not so easy to work on). The LS1 will probably just take the beating. But, if it doesn't for $1500 I can pick up a replacement all aluminum, 400hp "race" motor. How much would an all aluminum 400 hp SBC cost? Can I pick one up at a yard or ebay?
In closing, can we have a thread w good info for those who are or may want to do the swap. Instead of a lot of uninformed or grossly biased nay-saying?
#40
See, this is what I am talking about. Far be it from me to stop someone for posting their opinion. However, this is in no way helpful. And your facts are, well, wrong.
