What would be the most HP that the factory DM and clutch can handle? I am planning a rebuild on a LT-1 with a 5-6k budget for the engine. Need advice on component selection. I will do the wrenching. Thinking of having the heads ported and i definitely need to replace the crank. I am not to keen on having the stock crank reground. Please chime in with your opinions.
Thanks,
93cruiser
C4 of Year Winner (appearance mods) 2019
I've asked that question alot. Opinions have come from several (historical) retailers and the ZF Doc. Also, some users.
Really, the answer depends on how aggressive you'll be driving the car. If you'll be racing, revving, and dropping power into the clutch HARD, it's going to wear out faster. Official numbers I've seen say it can handle about 425hp/tq. OTOH, I've heard of people using them successfully well above 500hp.
If your power will exceed 400hp/tq, you better be easing into it most of the time or I wouldn't count on it lasting. But, if cruisin/street driving is your gig (with the occasional burst), you've got a little room above that.
Thanks, that is what I am looking for. This is a daily driver with the occasional romp. I am going to build a 400 rwhp engine. The block is in super condition. The cylinder bores show zero ring groove. The rod bearing journals were sloppy. Not sure how the mains are at this point. I am thinking that I can reach that goal with a stock rotating assembly or maybe a forged bottom end. Figuring out the top end is going to be interesting as there are many opinions as you know.
I'm putting down around 440rwhp and 418rwtq... I don't dump the clutch, no burn outs, etc.. I've had zero issues with it holding but I have a pressure plate that is 200lbs heaver.
Carolina clutch put the package together for me.
I talked to Tom @ Carolina Clutch. He said he'd never "recommend" putting a higher pressure platch with the stock DMF unit. He added that it could be done -- but would seriously shorten the life of the DMF.
The ZFDoc confirmed this attitude.
So...If you need more holding power,,,go with a stage 2 or higher clutch.
Wow! I was never told this when I ordered my 200 plus pound pressure plate from them. Still will be installing it though.
